Bilstein PSS9 - finall
Old 05-20-2011, 03:07 PM
dariusf's Avatar
2023 CLA 250, 2003 CLK320
Finally after many delays I got the Bilstein PSS9 coilovers installed. Picking up the car today. Can't wait to see it and test drive it.
I got these used from another mbworld.org member and a few parts were missing. Bilstain had them on back order for ever and just got them beginning of this year. Finally found some time and a shop to install them.
I checked several places. Got quoted $1200, 700, 600, 500 and 400. I chose the shop that quoted $500 as they seemed honest and had experience with European cars.
Here are a couple pics I took before the install
Old 05-20-2011, 03:13 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Looking forward to seeing some pics, you shouldn't be disappointed.
Old 05-20-2011, 03:24 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
You'll like the ride for sure. You might need spacers depending how much you want to drop.
Old 05-20-2011, 10:31 PM
dariusf's Avatar
I have 3mm on front from the start. Tried to add H&R 10mm spacers on the rear but they interfere with the Mercedes center cap. The part that sticks out is too far extended. Need to look for alternative.
The car looks great, I did not go too aggressive, do not like too tucked in look. I need to take after pics. As it is set now, there should be no rub issues, I hope. Also did not feel like I needed alignment at all. The rear camber also looks same as it was before. Did not measure but its not a change I can see. I only dropped 1/2 inch in the rear and then matched the front. Originally the space from the fender edge to the rim top was front: 4 5/8 in rear: 3.5 in
The ride quality on the other hand, well lets say its not a Mercedes any more The mechanic that adjusted them was not in the shop when I picked up the car and the owner was not sure what stiffness settings they set. I hope its on the hardest so I can adjust it softer
The car also feels faster I took some quick turns and it was sticking very nicely, no roll etc. very cool.
Old 05-20-2011, 10:35 PM
bheng's Avatar
2003 CLK 320
haha very nice. get some sways =P
Old 05-20-2011, 10:54 PM
Klinh's Avatar
Yeah, I also need a 3mm spacer too when I installed the KW coilover 2. As for the wheel cap, it really not the spacer but more of so the way your wheel "center" design. Your wheel center does look alot deeper in from the pics. I never ever have any problem with the wheel cap when running spacer on all mine Mercedes. As for adjustment on the coilover, turn the adjustment knob all the way to the left until it stop. Now, turn it slowly all the way to the right and count how many round/circle until it stop. This way, you will be able to find the middle/mid-way of the adjustment. Adjust all your struts/shock to the mid-way adjustment. Drive it around a couple days then make adjustment from there. Usually, turn back/counter clock wise for softer and forward/clock wise for harder.
Old 05-20-2011, 10:58 PM
dariusf's Avatar
Old 05-20-2011, 11:00 PM
dariusf's Avatar
thanks for the adjustment tips
Old 05-20-2011, 11:02 PM
dariusf's Avatar
Ps I know I have to wash the car but we have rain for the weekend
Old 05-21-2011, 06:08 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Beautiful drop! It looks great. Soften them up a bit and you should be happy.
Old 05-21-2011, 11:03 AM
dariusf's Avatar
Thanks, it looks much better in daylight. I like how you have the rears pulled out. I need to try to find proper spacers or get something fabricated Do you have any closeup pics of your rear? specifically by the fender? did you have to roll you rear fender any?
Old 05-21-2011, 11:13 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
No rolling necessary. These are the best one I have of the rear.
Old 05-21-2011, 11:23 AM
dariusf's Avatar
Here is better illustration of what I have now. Its H&R 24556659 10/6A 12mm
The lip is way too tall at 33mm, I need it at the most to be maybe 25mm to not interfere with the center cap.
I googled this model number and I found one that had this pic, not sure if that the actual pic and if they changed the design.
Old 05-21-2011, 11:25 AM
dariusf's Avatar
this looks great, thats what I need to get to
Old 05-21-2011, 11:27 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
If it will help, I could measure the lip of the 10mm H&Rs I have when I get home.
Old 05-21-2011, 11:35 AM
Klinh's Avatar
The 1st pic is the front spacer and it should only be use in the front. The 2nd pic is the rear spacer with lip only about 5-10mm long.
Old 05-21-2011, 11:54 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
, I don't know how I missed that.
Old 05-21-2011, 12:36 PM
Klinh's Avatar
I were thinking of the same too, how could Dyno not knowing the different with so many thread posted about the different spacer between front and rear.
Old 05-21-2011, 12:56 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I guess I had a brain fart. lol
Old 05-21-2011, 02:00 PM
elijah's Avatar
Euro Cars Only
Very nice setup!!
Old 05-21-2011, 03:03 PM
2MCHCAR's Avatar
Supercharged CLK500 & ML500
It looks great dariusf!
Old 05-21-2011, 04:02 PM
dariusf's Avatar
Ok now I feel stupid, I had no idea that there was a deference. The lip on the fronts is so large that I would guess even 10mm spacers would not really need extra lib. My rears have a very small lip so I assumed that big 33mm lip was for that. Oh well, live and learn. So now I need to get a proper rear spacer. I think I will go with 10mm.
From what I remember you should get about 6 turns for the bolts to stay safe? I have a bunch of bolts so hopefully a set will work with out being too short or hitting the e-break.
Thanks guys for all the info, this forum rocks!
Darius
Old 05-21-2011, 04:05 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Good luck. Be sure to post the final pics.
Old 05-21-2011, 04:06 PM
dariusf's Avatar
Thanks all for the positive comments. I like the wheels but they are a bit racy. Which for some is a good thing. The finish is nice as well as its a dual tone with only chrome on the lips.
Old 05-21-2011, 04:08 PM
dariusf's Avatar
will sure do, now I need to concentrate on the Dynavin audio install. Still waiting for some of the parts. Some came in this AM got to check the package.
Quick Reply: Bilstein PSS9 - finall
