Can this be a MAF Issue?
i am having this weird problem. i was driving and got stuck in traffic and i needed to make a turn, so i Reversed, and then shifted to D & kind of floored it... the car didn't do anything. No Spin wheel, no nothing... so i took my foot off the gas, and then pressed the gas pedal gently and everything went fine.
i previously drove an infiniti and as soon as u step the gas pedal , the ESP keeps on shining of wheel spins. Now i know i don't have the same torque, yet i guess i should have something when i floor it and its standing still for my CLk 240.
(one more thing, can this be something related to the MAF? been lately having some signs as in RPM slightly not stable on idle; when going up a hill on a steady foot, i feel the RPM is slightly out of tune +/- lets say steady at 2000 RPMs, it feels going down (-100 RPMs and back to the 2000 RPM) . i know the MAF does not give any warning on the dash until it is dead).
Thanks in advance everyone!
Thanks Kevwood, but assuming ur TCU registered a complete shift, what should happen when flooring the pedal from a stand point?
and any thoughts related to the MAF issue i described at the end of the topic?
Thanks again
As for the other issue, certainly could be the MAF. I felt like my car slightly surged while highway cruising and has an intermittent shudder at an idle, after I removed and cleaned my MAF everything was a-okay. If you are going to clean the MAF, make sure you use a proper electrical contact cleaner that is residue-free.
Best of luck
Best of luck
Thanks again. will try cleaning the MAF.
One more thing, from a stand point (0Km/Hr), and a kickdown to the pedal, would you have a wheel spin that would be controlled by ESP or would the car launch slowly and accelerate on higher RPMs?
Don't forget, no residue contact cleaner!
That's something i am facing now. On stand point, as if i`m driving a Prius! i guess that can be because of the MAF. so i`ll go step by step and hopefully the MAF would fix everything from my side.
Kevwood thanks again man. btw, ur 3 hours in plane from Beirut, hit it up on ur vacation time, this month would be a blast, in case u came, u have a CLK here (well not 500!!) that can cruise u around town
Same offer to you next time you find yourself in Dubai mate
No CEL's. Will check STAR system tonight.
Is it trannie rebuild time?
Pardon -thread jack
