Need some advice on my engine noise please !!!
Here is the video link :
to be an lifter or internal engine component in general it is rotating to fast....
It also, like I mentioned sounds like something is rotating out of balance...
thats all I can say and is of course dependant on throttle
mechs please!
I ask cause I got no cel and like I mentioned before my engine runs smooth !!
This is a purge valve.
http://www.google.co.za/url?sa=t&rct...2c8-QA&cad=rja
video:
As Rudney said earlier. remove the Poly V belt to ensure that it is not an accessory. If not take an oil sample & send it to Blackstone for analysis. That will tell you if something is destroying itself in the engine.
Cheers _PTEngineering
so what cause the sprocket to wear down? Loose timing chain ?
It is possible that it is the oil pump simplex drive chain as suggested above. This chain is lightly loaded so unlikely unless the tensioner spring 41 has failed.
Sometimes the tensioner is the problem with noisy cam chains. External replacement method is in the Wiki.
video:http://www.youtube.com/watch?v=G0iP2UMwW5A
