key fob wont turn over
Old Jan 26, 2014 | 12:18 PM
AMG_Adon's Avatar
05 E55
So my primary key fob wont turn over... it unlocks and locks my car but when i put it in the key receiver it does not turn... my spare key turns the car on just fine... anyone experienced this problem? what can be the cause of this ?
Old Jan 26, 2014 | 09:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
First, i would check the vehicle battery. That may not be the culprit, but a weak battery can cause all sorts of electrical gremlins, including "killing" a key. For example, leaving the key in the ignition and then the battery dying can ruin that key. There is really no way to re-sync a key - once it gets locked out, it's toast.
Old Jan 26, 2014 | 11:08 PM
AMG_Adon's Avatar
05 E55
what level should the battery voltage maintain? and i think thats what happened i left the key in the ignition while i was putting on my spare tire because i had a flat ... i took the key out after i get the spare on and few mins later tried to ignite the car and it locked out and the key led fob blinks
Old Jan 27, 2014 | 09:24 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Battery should show 12.6v at rest, no less than 11v during cranking as the starter runs, then around 14.2v with the engine running.
Old Jan 28, 2014 | 07:17 PM
AMG_Adon's Avatar
05 E55
thanks appreciate it any really good battery u recommend? i think my amp is causing the drainage possibly and one more thing im sure this is not battery related but i got a SRS code today and now the passenger seatbelt does not pop out when the door closes thats odd first time i ever got a SRS code
Old Jan 28, 2014 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I like the MBZ batteries. I think are made by Varta.
Old Jan 29, 2014 | 06:02 AM
AMG_Adon's Avatar
05 E55
OoO ok thanks again... I have a question another question for you my car says restraint system malfunction and has the SRS code ... And my passenger seat mechanism doesn't come out anymore any way to quick fix that witout the dealer ?
Old Jan 29, 2014 | 10:41 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Nope. Most all SRS errors are "persistent" and can't be cleared until the underlying fault is corrected, and then the error is reset via SDS (or other high-end scan tool - not generic OBDII).
