My Engine Died! R.I.P
Old Mar 19, 2014 | 01:06 PM
boull's Avatar
CLK 240 - 2003
Angry My Engine Died! R.I.P
Hi Everyone,
to do a recap, i had my car since 2.5 years. its a 240 Engine.
it has 155,000 KM on its ODOmeter (96000Miles)
i keep regular oil changes with MAN filter (used Mobil 0-40 Full Sync) and then switched to Fusch lately.
since a month ago, start seeing white smoke on cold start up for like 3 seconds and it runs smooth. when i inspected the scent, it smells like really burned oil.
the second issue i started seeing is the gas consumption. my car started doing around 14.5L/100 KM and eventually that really dropped.. so i was doing like 90-85Km/20L...
the mechanic told me that as if i didnt change oil since a lifetime which is not true, and he said that it could be that the previous owner didnt attend to his car too much
My question is as follows:
what would have done this? is it true that this shows after much time i have owned the car?
already started searching for a 320 engine.
yet all i want to know is how did i get my engine to :
here are the images after putting it for repair (engine opened)
Old Mar 19, 2014 | 01:43 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
That definitely doesn't look like anyone did any sort of regular oil changes on that engine.
Old Mar 19, 2014 | 01:48 PM
boull's Avatar
CLK 240 - 2003
As per many threads i read...
Mobil 1 0-40 can run up to 10,000 KM so i ran that oil till 10,000 Km and did the change once the interval beeped.
when i changed to Fusch, i did the change on 5000Km to 6000Km on the engine.
... i drove the car for 55000 KM on my watch... so the last 2 oil changes where Fusch and the others were all MOBILE 1
Old Mar 19, 2014 | 02:02 PM
megacrazy's Avatar
Yeah nothing wrong with the oil you used but see all that sludge? Did you do the changes yourself or did you take it somewhere?
Old Mar 19, 2014 | 02:50 PM
Glyn M Ruck's Avatar
Super Moderator
Oh my oath what a mess. Someone neglected that car at sometime in it's life. What mileage did you get her at? Looks like she might have overheated at some time as well.
M112 with similar mileage run on 229.5 oils changed at 15,000Km intervals with fleece filter.
Old Mar 19, 2014 | 03:26 PM
pskdude's Avatar
2004 CLK500 - W209 - Cabrio
Wow...I just recently purchased a clk500. and changed the valve cover gaskets since they where leaking. here is what the inside of mine looked like. I assume they did frequent oil changes. im @ 110k miles
Old Mar 19, 2014 | 05:00 PM
Super Moderator
That is what it should look like. I hope this convinces people to use approved oils.
Old Mar 19, 2014 | 11:17 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, when I changed the valve cover gaskets, my C240's M112 engine looked just like Glyn and pskdude's - nice a golden from the Mobil1.
Boull, that engine definitely looks like it overheated. And there is an awful lot of "sludge" in there. This is not normal for that engine.
Old Mar 20, 2014 | 12:22 AM
tee's Avatar
tee
E55,GL 450,Subaru STI,Chevy crewcab
I have seen this before from non synthetic oil and trying to go 10-13k service intervals.
I dont think this is a mobil 1 engine.
Old Mar 20, 2014 | 06:05 AM
boull's Avatar
CLK 240 - 2003
Om MY!!! i really have quite a mess!!
i got the car on 62000 Miles (100000 KM)
i just bought an engine today, couldn't find a 240 engine, so i ended up buying a 320. as per the mechanic, everything can fit from the differential to the transmission.
it never overheated on my watch... so i`m trying to figure out if that is my case... but would that mess be pilling up since the last 2 years i got the car?
Old Mar 20, 2014 | 08:16 AM
xsever's Avatar
2012 C300 4MATIC Sport
How much was that 320 engine? I am interested in seeing how your mileage will vary now as well as the "feel" of the car with the more powerful engine.
Old Mar 20, 2014 | 08:23 AM
boull's Avatar
CLK 240 - 2003
if you are referring here to mileage of the 320, sorry man.. they are not that slick in giving you these info.. yet i bought the engine today and i guess they will start putting it in the car tomorrow.
once i have it running will keep you updated with the stats..
mainly my 240 used to do 160Km/20L. (this includes 60% in city and 40% highway)
as for the feel.. i will definitly feel a change, the 240 gives a 179 Hp while the 320 gives out 218Hp.. so i guess the difference would be noticeable.
Old Mar 20, 2014 | 08:24 AM
xsever's Avatar
I was asking about the price of the 320 engine
Old Mar 20, 2014 | 08:48 AM
boull's Avatar
CLK 240 - 2003
Sorry man, my Bad
Engine > 750$ (2005)... note that it is stripped from everything.. you just buy the block
Old Mar 20, 2014 | 06:19 PM
Super Moderator
If you were running 229.5 oils on your watch as you have described I would have expected it to start cleaning things up. It must have been awful before you bought it.
Old Mar 20, 2014 | 06:57 PM
AMG Boost's Avatar
2010 C63 P30
That is some of the worst sludge build up I have ever seen! If I was to guess the cause of this I would say non-synthetic oil was used for long over 10k kms.
Old Mar 20, 2014 | 10:12 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
Wow, my jeep Liberty with 100000 miles is cleaner, sad to see an engine treated like that.
And the miles should not be that bad, my 350 and 550 get closer to the same miles
Old Mar 21, 2014 | 04:18 AM
boull's Avatar
CLK 240 - 2003
Played by the book... full Syn. Oil.. 229.5 Recommended MB only went into that engine on my watch with Fleece Man filter.
so that is what is leaving me thinking .. how can that much sludge built up there!
Old Mar 21, 2014 | 04:19 AM
boull's Avatar
CLK 240 - 2003
as described .. seems the previous owner was a d**khead treating the car in that way.. that is the only thing that comes to mind
Old Mar 21, 2014 | 04:50 AM
boull's Avatar
CLK 240 - 2003
My new (Used) engine was delivered today morning i got to see it!!!
The engine will be running tomorrow morning.. so crossing fingers that everything would work fine.
Old Mar 21, 2014 | 05:54 AM
Beichtvater's Avatar
CLK320
Attachment 281965
Looks good.
M112.940 has 195k Miles on the clock. Running on Mobil 1 0W-40
Old Mar 21, 2014 | 05:57 AM
boull's Avatar
CLK 240 - 2003
Originally Posted by Beichtvater
Looks good.
WaW 195K!!!
you gave me something i was searching for...
M112.XXX , where can i find the XXX values to know the engine types.
i was told the engine i bought was soemthing M112.95 something i guess...
just want to check what that is!
i guess the one i bought was a M112.955 whereas the one i had installed/burned was a M112.940
Old Mar 21, 2014 | 06:20 AM
CLK320
WaW 195K!!!
My Engine would probably look like yours if i would not clean the vent/degassing holes in the head cover last year. It is a known problem of the M112 engines. http://www.m112technikcheck.bplaced....nalproblem.htm
Also the oil draining hole in the head can have a cast skin that makes problems and has to be opened and look like this.
http://www.m112technikcheck.bplaced....inken%20ZK.jpg
The Engine number depends on the type of your car and model year. Usually written down in your Datasheet. I can see it with the vin in my EPC/WIS.
The number usually is located underneath the engine, not easy to describe. In the area where the engine and transmission meets.
http://www.teilehalle-fm.de/ebay/Fot...4/CIMG9664.JPG
Old Mar 21, 2014 | 06:29 AM
boull's Avatar
CLK 240 - 2003
interesting.. thanks for the headsup on that..
i don't have a VIN on my car, its not US Spec. but i guess my engine was something of 940 as i understood from the mechanic on the phone and to upgrade to a 320, i need the 955..well something like that
Old Mar 21, 2014 | 06:35 AM
CLK320
I have the W208 320 with the m112.940 and i guess the W209 320 has the M112.955. I live in Germany and my car isn´t US spec. too
