Please help, 8 months and my car still won't start :(
So, on July 2, 2013 on my brother's birthday I was driving home and swung by my shop to pick up my laptop. I turned the car off for a brief 5 minutes and when I returned to the car, it would not turn on! The car would crank, crank, crank, crank, crank but not turn over (turn on/vroom vroom--- go home) Needless to say, my girlfriend and I rode home as passengers of a flatbed tow truck that evening.
The car sat outside my house for another month while I glared at it, and occasionally kicked it. Then I decided to research the topic and everyone was saying either the crankshaft position sensor or the CAM sensor. I was able to get a Crankshaft Position Sensor from my local mechanic and replaced it, but it did not solve the problem. I am beginning to think the sensor was either faulty, incorrect, or otherwise. (luckily I did not purchase the sensor but it was given to me for free)
As for the CAM sensor, I have been unable to find a diagram pointing out its location... so it still remains a mystery.
Then I had the car towed to a place near me that had replaced the air strut on my w211 a while back. The car sat at his shop, in the back, for 6 months... and he did nothing, and still doesn't know the problem. Supposedly he had checked all the wiring and it is all good, and everything is grounded properly--- but that's all he did in 6 months. Luckily I haven't paid him more then $300.
Anyway, I need to get this car fixed! I am going to have it towed back to my place and would like to know where to start fixing. I plan on replacing all the fuses with high quality ones (just to make sure its all good)... but in terms of sensors/actual fixing, where do I start? Please respond to this and answer as if I was the dumbest person ever, feel free to over-explain with small words and pretty pictures.
Side note, I had asked why the parking lamps (left front & right front) never worked since we purchased the car and never gave an error--- and someone said that the fuse box under the hood could be faulty, could that be a contributing factor as to why the car will not turn over?
Thanks!!!
The car either cranks or it doesn't. Your explanation is confusing.
If it does not crank then check fuse 52 & make sure it is 20 amp. Also check the starter relay in the front SAM. Then finally check starter motor. Worse case scenario is a failing EIS or front SAM or starter motor.
If it cranks over but does not start then the two likely culprits are lack of fuel pressure or CPS. Fit a new CPS & check fuel pressure at the Schrader valve on the front fuel rail. It should be 3.8 bar or 55 psi while cranking. If it is not you either have a failing fuel pump or a clogged fuel filter.
https://mbworld.org/forums/c-class-w...t-process.html
Dealer installed a new "computer" the same day and it was fixed. Didn't cost too much: less than $800 all in. Towing was free. The dealer even dropped the car back to my home.
Sometimes, bringing the car to the dealer is the *cheap* way.
A dealer bill of $800 means they did very little.
I really can't afford to tow it around everywhere.
Thanks for the responses! Hopefully I will get more on this thread and help me wrap my head around this fiasco!
I keep getting shotty "information" that the place where my car has been for the past 6 months did "more work"
First it was only that he checked the wiring, now he's sure it's the neutral safety switch, now he's sure it's the ECU... then he tells me that he had already plugged in two ECU's and the car fried both of them and that's how he knows we have a "dire problem"
I should have the car back into my driveway about Friday or so and then I'll start working away. (Starting with the fuel pump and working my way to the sensors) I also plan to replace all my fuses with ones that light up when they pop, so I can easily tell if I'm blowing them.
I'll keep everyone updated & hopefully it's something simple and I don't need to "replace all the modules" like this other guy said.
Daimler's purchase of Chrysler did nothing to affect the quality of MBZ vehicles. Most of the quality problems can be traced to suppliers. MBZ has historically done a poor job of managing its suppliers. On top of that, they push hard on them to supply parts faster and cheaper. if you want something done right, do it yourself, but if you must hire it out, expect to pay for quality. BTW, that's the basic summary of a 500+ page document delivered to MBUSI bac in 2004 from a certain group of QA consultants hired to help them improve quality in preparation for the production of the W164, based on experiences with the W163. I think they read some of it.
Now, I replaced the Camshaft Position Sensor. The Crankshaft Position Sensor, All fuses, and checked all relating relays.
Car still cranks, and I can smell gas--- but it does not ignite (I am hoping I am using the correct terminology) Today I removed the rear seating and the under-cover to expose the two chambers housing what appears to be nothing (maybe the fuel filter?) under the passenger side, and the fuel pump on the driver's side.
My somewhat knowledgeable buddy who was here with me today told me to put the key into position 2 in my 2005 E Klasse, and that I should hear the fuel pump power on, which I did... then when I tried it on my CLK I heard nothing, even when the rear seats were removed.... could it be a failed fuel pump??
I'd like to know before I call the dealer to take my car...
I wish I could afford to just make it the dealerships problem... but I can't. I build saltwater reef tanks and right now people don't really seem to think of them as 'necessities' haha
Thanks for being so calm with me guys. I'm only 20 with no mechanical experience so it's a learning process here, I appreciate every ounce of effort you guys put forth into your responses!! What I learn comes from you guys and this website/YouTube in its entirety!
I have new news as of today, and was wondering if any members could shed some light on this.
I purchased a code reader from Auto-Zone today for $49.99 and it seems to do the trick for me. Now that I replaced the fuse & the car cranks, I can pull codes. So this is what I have and what was pulled. The manual/readout for the code reader isn't very helpful with these "other" items that it pulled. I added what the reader pulled up, followed by a hyphen and what the manual called it.
Actron OBD II PocketScan (CP 9125)
0 codes
MIL- off
6 INC incomplete (vehicle was not driven enough under proper conditions to complete the monitor)
Catalyst - Catalyst Monitor
Evap - Evaporative Systems Monitor
Sec Air Secondary Air System Monitor
02 Snr - Oxygen Sensor Monitor
02 Htr - Oxygen Sensor Heater Monitor
EGR - Exhaust Gas Recirculation
3 Ready (vehicle was driven enough under proper conditions to complete the monitor)
Misfire - Misfire Monitor
Fuel - Fuel System Monitor
Comp - Comprehensive components monitor
Also, I don't have a fuel-pressure test kit, but when I checked the fuel rail in the engine... it shot out about 1 tablespoon of gasoline, and that was it. (see picture)
Is my fuel pump the problem??
& if it is, is it the contraption that is under the driver-side rear seat? That seems like a pretty easy fix/replacement if it is.
EDIT: Rudeney's method is to energise the pump without attempting to start the car or without car running.
but during the time I was going out, I would eventually be able to crank and start the car it took several tries but it did start up. I know you said you installed a another one, I would perhaps recommend picking a new one up from the auto part store and trying that if you can easily access the sensor. Good Luck!
