BENZ CLK500 Open roof issue
Old Jul 15, 2014 | 02:08 AM
kensmith's Avatar
Benz CLK500
Dear All,
Suddenly all my roof light stop working,my boot was automatically look, i can't even open the boot with the key or soft button by the door and on my dash screen it said Top in operation. if i remove the key it said top is open why roof is lock.
I have check the engine front fuse and the driver side fuse, no fuse cut but i can't check the back boot fuse because the back boot is look and it can't open with it own key. when i press the open roof button it said visit work shop.
Please help me because i wonder why the roof light and the boot lock at desame time.
Old Jul 16, 2014 | 08:25 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It could be a bad microswitch that is not recognizing that the top is closed. Try tightening the windshield lock using the Allen wrench tool in the manual slot on the header. If that doesn't work, you may need to manually open then close the top (instructions for manual closing are in the owner's manual, and I know I have also posted a video here showing the details).
Old Jul 17, 2014 | 09:53 AM
kensmith's Avatar
Benz CLK500
BENZ CLK500 issue
Dear Rudeney,
How do i locate the video ? Even now that the trunk can't open, how do i open the roof manually why the trunk is lock ?
Old Jul 17, 2014 | 10:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If the soft top cover (the panel between the trunk and the back seat) is definitely closed, you should be able to manually open the trunk lid. Insert the mechanical key in its lock, and turn it counter-clockwise, then holding it there, pull on the handle. This should open the trunk so you can access the locks for manual open/close of the top.
Your owner's manual had instructions for manual closing. For manual opening, it's the same except that you "unlock" the top at the windshield, and once the rear lid is popped open, you lift the glass, then open the lid, then fold the top into the trunk. Here's the video for manual close:
http://benzbits.com/w209/soft_top/ManualClose.wmv
If this seems like too much to tackle, you might want to get professional help from a dealer or MBZ-specialized indy shop.
Old Jul 18, 2014 | 09:21 AM
kensmith's Avatar
Benz CLK500
BENZ CLK500 open roof issue
Dear Rudeney,
My first priority is how the trunk will be unlock.
I have tried several time trying to unlock the trunk with the mechanical key but it won't unlock, i'm sure that the top in-operation is what lock my trunk.
Can i unlock the trunk through the back seat?
I took the car to a dealer and he check the engine under the trunk plate number and he said that the trunk can only be unlock through electrical.
Kindly advice.
Old Jul 18, 2014 | 10:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The "emergency" release button on the inside of the trunk will not work if the soft top is not recognized as closed - it uses the same electrical interlock as the button on the driver's door.
When you tried the mechanical key, did you pull the handle with the key rotated clockwise? Note that just rotating the key does not unlock the trunk - it simply moves a cog inside the lock so that pulling the handle will then mechanically release the latch. It's purely mechanical so top open or close should not matter (of course you would not want to open the trunk lid unless the soft top cover is closed, otherwise they will collide and be damaged).
Old Jul 19, 2014 | 08:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just to verify, I went out to my car and started the roof opening and then stopped it. I verified that I could not open the trunk with the handle, SmartKey fob button, or driver's door button; with the top not completely opened or closed, the trunk lid latch is electronically disabled.
I then inserted the mechanical key in the trunk lock, rotated it 90-degrees counter-clockwise (as far as it will go), held it in that position, then squeezed the handle. The trunk lock released and I was able to open the lid.
Old Aug 22, 2014 | 01:46 AM
kensmith's Avatar
Benz CLK500
CONVERTIBLE SWITCH BROKEN
Dear Rudeney,
I gave my car to my friend to drive but he end up messing up my convertible.
He broked some component from the convertible part, i want to buy the broken part but i don't know the name of the part..kindly view the attached of the faulty part damaged by that stupid friend of my....please help me with the part number and where to buy them.
Please view the pictures you will see that the left switch is broken why the other pics is the right switch that is okay why the other pics is the right cover but the left cover is broken.....please help me i want to buy this part but i don't even know the name of the part.
Attached Thumbnails BENZ CLK500 Open roof issue-1408551904159.jpg   BENZ CLK500 Open roof issue-1408551854540.jpg   BENZ CLK500 Open roof issue-1408551865973.jpg
Old Aug 22, 2014 | 04:57 PM
kensmith's Avatar
Benz CLK500
Can any one please help me with the part number ?
Old Aug 23, 2014 | 11:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I believe the switch is part number A2098201910. I am not sure what is broken on the flap - there are several parts to it.
Old Jun 9, 2015 | 06:50 AM
Lion70's Avatar
Clk w209
Clk w209
Hello every one, i have the same problem on my clk w209 the back side of the roof get stuck on the opening and will not lift, this is after i change the line 22 of hydraulic roof, also i notice my switch it is broken like yours.. Did you find a solution?
Thank you
Old Jun 11, 2015 | 03:47 AM
Lion70's Avatar
Clk w209
Hi I manage to change the micro switch part number A2098201910 and all works perfect, time changing 20 minutes job done, thank you all for the information posted in MBWorld..
Old Jun 12, 2015 | 12:31 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Glad you got it sorted out!
Old Jun 21, 2015 | 07:33 AM
jamesDD's Avatar
2006 merc CLK convertible
convertible stuff
Hi Rodney,I have a 2006 clk convertible,I watch your video on to raise the top manually .I looked at my car my my nut is in silver I turn the key left.Then I try the pull the silver thing out and turn it left.it will not stay out .So I think am I turning the right nut with the key the tank is layed on its side thank you I DONT HAVE A PROBLEM JUST IN CASE THANKS
