need help running aftermarket amp Power Wire.
" For speaker-level applications,
a remote connection is not required,
since BassLink’s Auto Turn-On feature will
sense voltage on the speaker wires to
automatically turn on BassLink."
20A fuse required.
From what I see in this thread, if my amp needs a fuse lower than 80a I can just use the SAM for power?
My amp will want a 60a fuse (Clarion sub amp).
I intend to put a sub in the rear driver side footwell (ie where the rear passenger behind the driver would put their feet). I will remove the sub for the rare time I have 4 passengers, so far it is usually 1-3.
I am also considering simply disabling the stock sub, and using that signal to the new sub amp. I find the stock sub does not do much for me.
while you can run it off the sam i would not. Spend the extra time and money to run a dedicated line with and inline fuse/breaker no more that 12" from the battery. These cars are odd when it comes to power draw. I have never had an issue with a dedicated line though. Just an example. My fuse housings for the AC system recently melted. They did not pop the plastic part melted. That was a result of bad brushes on the blower motor drawing slightly too much power.
