2005 CLK 500 Stalls on Heavy Acceleration
Hey Guys, I have a CLK 500 (2005) that stalls when i really get into it. Sometimes at 80 mph. I have replaced the CPS do to running rough and stalling at stop lights. Those problems went away and when i drive the car like a normal human being it does just fine. What fun is that? Now that my daughter is driving this I am concerned she we try to pass and stall. Any ideas? Thanks in advance...
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Is a CPS code the only one stored? You could have a fuel rail pressure issue. Pressure needs to be 3.8bar or 55psi. Could be fuel pump or clogged filter. Your car is right at the changeover point. Could still have an external filter or an in-tank filter at the fuel pump. Make sure that the airbox is clipped down firmly over the MAF at the rear of the engine V. Loose airbox does not throw a code.
It could be the harness but not common.
EDIT: BTW the cause of CPS failure is heat over time due to location. Sometimes pouring cold water over the CPS will revive it for a while.
if the wiring is damaged it could be not getting the signal from the cps. I agree thats not common but if you keep getting cps codes i would look at it.
I also agree with Glyn, it does sound like a lean issue, that would have been my first thought except for the continuous cps issue
2007 BMW 550i
I had a similar issue when i installed a used fuel pump in my old C230 (i was stranded at night and all the shops were closed, my mechanic had a spare unit around) everytime i'd push the car continuously it would stall, ended up changing the fuel pump and it solved my problem. Though STAR should be able to tell the difference between a CPS fault and not enough fuel.
Super Moderator
Fuel pressure should be checked at the Schrader valve on the front fuel rail that connects the injectors at the above values while cranking.
