What are 2 wires under back seat
Old Mar 23, 2016 | 04:09 PM
Dbora94's Avatar
Clk 320
Just bought my clk and Was tightening my handbrake and seen that there is 2 wires leading from the front and have been cut and tied up. What are they??
Noticed My seat bolsters won't work but I'm sure they were working when I picked it up, also my parking sensors don't work
Dunno if these are related
Old Mar 23, 2016 | 05:18 PM
Reanimation's Avatar
270 cdi w209
I'm sure they are connected to the Seat Belt tensioners.
Old Mar 23, 2016 | 05:35 PM
Dbora94's Avatar
Clk 320
The seat belts tensioner aren't right as you can see in the picture so maybe it has a hidden past 👀
Old Mar 24, 2016 | 03:01 AM
DanielFD's Avatar
2007 BMW 550i
those 2 wires are for the seat belt tensioner , theres probably a capacitor in there to fool the SRS system that the tensioner haven't been fired. it seems your car has been in an accident, and for cost cutting they just installed capacitors on the belt tensioner instead of replacing them. probably the same story with the front seats. any airbag errors?
Old Mar 29, 2016 | 05:51 AM
Dbora94's Avatar
Clk 320
Nah no errors.
With these not being connected what does it mean? What won't happen with them not being connected?
Old Mar 29, 2016 | 06:08 AM
DanielFD's Avatar
2007 BMW 550i
basically these tell the tensioners to pull the seat-belt anchors down in case of an accident for better safety. Them being disconnected wont mean anything, it is theoretically "less safe", I wouldn't be worried about that. I would be worried about looking around the car for damage that has been repaired in the same "cheap way".
DanielFD's Avatar
2007 BMW 550i
Oh and Seat-belt tensioners aren't reset-able they should have been replaced.
Old Mar 29, 2016 | 10:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Seat belt pre-tensioners don't always have to be replaced. It depends on which system is used. The older systems used a gas-charged cartridge that was a one-time user. Newer systems use an electronic servo that is reusable (self-resetting). I can't remember which system the CLK uses. I seem to recall seeing gas cartridges in mine. But if it fires, it will trigger an SRS Fault.
Old Mar 30, 2016 | 02:33 AM
DanielFD's Avatar
2007 BMW 550i
gas-charged on the CLK.
Old Mar 30, 2016 | 04:55 PM
Dbora94's Avatar
Clk 320
thanks guys! also i want to replace my flat badge with a bonnet star, is that possible? trying to find a kit on ebay as i know there is no hole in my bonnet so was wondering if they made a star emblem with a flat bottom that you could glue on
