CLK 550 Oil leak - Valve cover issue?
Old Apr 14, 2016 | 10:23 AM
totita's Avatar
C230 K
I have a small oil leak on the passenger's side of the car. The leak is not bad yet, it does not accumulate on the floor of my garage. The oil drips to the exhaust headers and it causes a bit of smoke and burned small. The oil seems to accumulate behind an unidentified part towards the back of the engine. It seems to be be a valve cover leak. I found no valve cover gaskets for the 550 engine, just this sealant: VICTOR REINZ JV8 Silicone SILICONE. The car has only 38K miles.
Anybody has any suggestions or instructions how to remove the valve covers? Just remove, clean and apply sealant?
Thanks.
Old Apr 14, 2016 | 10:38 AM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
is it leaking on the back of the head?
Old Apr 14, 2016 | 10:39 AM
totita's Avatar
C230 K
No the top of the head, the back of the engine. I'll try to get a picture. The leak is very small.
Old Apr 14, 2016 | 09:50 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The valve/head covers on the M273 do uses RTV instead of pre-made gaskets. And this rarely leaks (almost never form the factory). A common source of leaks are from the rear of the covers. The right side (USA passenger) has an oil centrifuge that is used to vent the crankcase. The left side (USA driver) has two plastic "cam plugs" that snap in place and are known to leak.
Old Apr 15, 2016 | 08:45 PM
totita's Avatar
C230 K
Found the leak under the centrifuge that is used to vent the crankcase. Should I just try to tighten the lower bolts or remove and use some high temperature sealer? I wonder if I remove the part oil is going to leak from the engine. Do ypu happen to know the part number ?Thanks
Old Apr 15, 2016 | 10:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Here's the WIS doc for removing the centrifuge:
http://benzbits.com/M272/OilCentrifuge.pdf
It has an o-ring style seal, but it is not available as a separate part; you need to replace the plastic cover which comes with a new seal - part number A2720100431.
Old Apr 16, 2016 | 08:18 PM
totita's Avatar
C230 K
Completed the job today. Thanks for the help.
Old Nov 3, 2016 | 10:24 AM
shehryar85's Avatar
1998 Mercedes Benz S500
@ totita
did you replace the part or just resealed it? I am having the same problem on an E550, i believe its the same engine.
Old Nov 3, 2016 | 11:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You have to replace the part - the seal is not available as a separate part. I just did this on my R230 and it was a 10 minute job. Granted there is a bit more room on the R230 to work, but its a few bolts and one hose to R&R.
