CLK 280 Rear clunk in an empty trunk/boot
Not sure if this is the right place to post? I think it will be a W209 (no 280's mentioned).
I have a clunk in the boot, this happens when I go over a speed bump, it sounds like there is something in boot bouncing around like a loose jack but it's totally empty, everything is tied down securely
I garage looked at it and said all was well and pointed out it could be a number of bushes, about 6 different ones, naturally I don't want to replace everything.
I heard that this 'body in the trunk' is common on some Merc's. Wondering if anybody has anything to input
Mark
Good point on removing everything, I was thinking the same thing myself just keep forgetting to do it.
I'm going to take it for a drive on a bumpy car park while I have the back seats down to see if I can pin point anything while the wife drives, but I suspect it just sounds like it's in the boot and it's a bush or suspension issue
It is a little bumpy at motorway speeds, I'd say a little bit beyond firm, you feel everything, but I've heard Avantegards can be like that. I put new continental contisport 5's on it (wanted Dunlop sport max but the tyre shop screwed up and I had to have something on that day) but they didn't help, in-fact I am sure they now cause a sound I have when I break, lots of road noise when on the breaks at higher speed, take my foot off the brake, quiet, back on, noise, again nobody can find the fault, maybe the tyres are bad, don't remember having it before hand.
Nothing more annoying than faults that can't be found.
I'd check exhaust mounts, drop links, and anti-roll bar bushings, initially.
When I have noises, I use a local garage whom I'm friendly with, they have a plate on their ramps which will shake the whole car, revealing any weaknesses.
Is there vibrating in the pedal; associated with the breaking?
The breaking - No vibration, I've had new brakes on it. It's kind of a whiring noise, best described like a lot of road noise like I have changed road surface, but the second I take off the brake pedal it goes. I suspect the it's the new tyres even though the tire shop says they are fine, the quicker I wear them out the better.
Whereabouts are you in the UK?
Btw: I did have the most bizarre grinding sound when I turned my wheel, this was last year, the garage put the brakes on, only to find it was not the brakes, it was a plastic clip that had broken holding the handbrake cable, and the cable was catching on the drive shaft only when I turned the lock one way (I know-odd). I can't be sure but I think it might actually started knocking after that, so I am wondering if they didn't put things back where they belonged. They have looked at it but didn't find anything, I need another set of eyes on it.
FYI I am located in Glossop, close to the bottom of the A57 snake pass, the best road in the world! ;-)
I heard that this 'body in the trunk' is common on some Merc's. Wondering if anybody has anything to input.
I'm betting on the sway bar bushings, but my indy stated they look fine. The sway bar bushings on these updated models is funky with the bushings and I feel like the only real cure is to replace the whole bar since the bushings are attached (from what I remember reading on the forum versus the older design with removable bushings).
And I actually getting a slight grinding noise when coming to a stop even though my brakes are okay, but could be time to change the rotors with the next pads change.
I have to say it started with me dropping the rear seats and having my wife drive over a car park that was cobbled, so I could go in the back to try pin it down, wow did that make me feel sick!
Here's what I did, I found that by pushing down on the boot lid that it had a bit of a squeak, I put some WD40 on a cloth and rubbed it into the boot seal, but then while pushing to test the squeak I noticed the boot was solid on one side, and I was able to move it a little on the right side, I could push it down a little. I adjusted the boot with the little twist out thingy on the boot, just enough to stop the movement, and not too much that shutting the boot required a slam, took it for a test drive over the same speed bumps.. fixed!!! I've driven it for some time now, over countless speed bumps, it's perfect.
No suspension parts required, no big bills. This car had been to a third party merc garage, and also to the main dealer, neither of them found it!
Oh the American's out there please replace boot with trunk ;-)
I don't think the lubrication that I put on the seals were part of the fix, but no harm done by softening up the seal before adjusting the truck to make it nice and snug.
Hopefully it'll also be the fix for yours, I've put plenty of miles on it now, and I have around 26 speed bumps in each direction to get out of my time (yes the road planning council are a bunch of a##holes), and it's not done it once, before it did it every single time, did sound like a suspension problem, and yet, like you said such a simple fix, it really is shocking that the main dealer never spotted it.
