transmission problem
Thanks for your replies.
Try this first. Also, when was the trans fluid/filter changed last? I would start with the easy stuff and go from there.
Between those two actions (transmission stuck in gear and it went back to normal) did you touched (moved) transmission shifter? If you'd accidentally put it in manual mode it would not out manual mode by itself.
It has not given me problems since.
I will do more research regarding how often to change fluid.
Thanks for your help.
