Is this Command Head Unit toast?
Real ones cost ~100USD used. Flip the disc around. If you see the part number imprinted on the clear centre part of the disc (where you pick it up with your index finger), then it will be genuine.
Another problem, you have the wrong disc. Your disc is for CL and S classes.
The correct disc for CLK is BQ6460328. You will see T1000-22938 imprinted on the back.
To my knowledge, you cannot revert to a previous firmware.
Make sure part # begins with A209, NOT anything else even if the Comand unit looks the same. It will not fit.
I believe A2098203189 should work for you. Better yet, take out your old Comand first and order the exact same part #.
Yes, it is plug and play.
