What does this alternator diode test tell me?
But as soon as I attach the alternator's positive pin to its cable (the battery is still completely unconnected) and repeat the same tests, I get a reading both ways (the same 500mv and a higher 800mv to 900mv when I expect 0 for the last test), indicating that the diodes are bad.
I am sure this tells me something, but what does it mean? Why does that happen? (Because of this, I replaced the alternator, but another "new/used" alternator does the same thing.) I'm sure it is something down the line, but I want some help finding the problem. (The battery is draining, and electrical problems)
Does your CLK have an auxiliary battery?
I updated my initial post to clarify that when connecting the positive to the alternator, I get a reading larger than zero in both directions. The first is the same ~500, the reverse where I had 0, now shows 800~900mv.
The CLK-500 does not have an auxiliary battery.
I can take a resistance measurement, but to be clear, you say: "take a resistance measurement (ohms) between the alternator's positive cable with it disconnected and ground"
I am not sure what you meant: Do you want me to measure the resistance between the alternator positive bolt and the alternator casing when the positive cable is not connected, correct?
I updated my initial post to clarify that when connecting the positive to the alternator, I get a reading larger than zero in both directions. The first is the same ~500, the reverse where I had 0, not shows 800~900mv.
So, with the battery still completely disconnected:
Alternator positive CABLE to the ground while not connected to the alternator: slowly runs up for a while... seems to stop around 4 (on 20k Ohm setting).
Alternator positive BOLT to the ground while not connected: sometimes 10 (on 20k Ohm setting) and sometimes almost 20. Can't seem to get a grip on it, every time I go into the garage I seem to get 10 or 20
That is how I ended up at the alternator because, as far as I could tell, none of the fuses that were pulled caused a change in the drain that was there. Fuses in Engine compartment, next to the steering wheel and in the trunk.
(or at least I remember there was a drain... like I said, eight months ago).
I read somewhere that it then can only be the alternator or starter. I tested the alternator and saw the "defective diode". So I decided to change the alternator.
Changing the alternator on a v8 MB CLK 500 is a real pain, as you must remove the radiator fan and disconnect some cooling hoses. So, I saved that job for when the Chicago weather gets better, which is now.
But then, after replacing it (the cooling fan is still not on the car), I found out that the alternator I pulled out was perfectly fine once it was out, which led me to the test of unhooking it.
And that led me to write this post before I put the whole fan and bottom back.
I didn't want to dilute my original question with all this extra info, but there it is.
I think both the old and "new" alternators are good, but I can't explain the diode behavior and am wondering if I should start looking into the starter. I was hoping that the readings would indicate something in that direction, but I am just guessing and reading everything on the internet without actually knowing what I am doing
I guess I will start reassembling the front of the car again and maybe start all over with the analyses. I was hoping the weird diode behavior would indicate that I was closing in on the problem instead of having to start all over again.
Last time I was working without help. Maybe this time I will post my findings to see if I can get more educated guesses
Thx so far.
I disconnected the batteries and did the CTEK conditioning... then I went to unplug the ALT LIN, but there is no way to access the alternator from either the top of the bottom. From the top there is a turbo in the way along with a ton of coolant lines, etc... from the bottom, there is no gap anywhere near large enough to get beyond the steering rack and associated frame plates to get to the back of the alternator.
There is a plate that bolts to the subframe and also the steering rack which, if removed, may allow a tiny hope for access... but those are some big bolts. I don't know the torque specs, and I don't know if the steering rack could be damaged without having this plate in place. To me it looks like a shop would have to remove the rack to get to the alternator.
Has anyone done this on the same platform?
https://mbworld.org/forums/w212-amg/...ml#post8793850
@CaliBenzDriver -- Do you happen to know where the other end of this line is routed - maybe which pin on the ECU? Maybe there's an easier way to interrupt that signal.
The ALT-LIN homeruns straight into ECU under its connector M where you can install a $1 On/Off toggle switch concealed under the cover.
See the main ALT-LIN thread... MB Forum has disabled "Edits": I cant index the content
Automatically show similar threads relevant to the topic you're reading when viewing the desktop style
Choose the Disable Related Threads radio button and hit save changes.
