SpeedtuningUSA coming tomorrow.
Old Apr 26, 2005 | 02:34 PM
JLee81's Avatar
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
I will write you with the first impression about the company.Seems like they buy the programs from other companies and do the thing. But..let's see.. I think it might be the similar program as powerchip but slightly detuned.
I should have driven at least 200miles before any dyno but well.. I checked out renntech box in 3days and I only had 7 horses at the wheel. TQ is the same. Which means that the loss of TQ was less as rpms got higher? I will have everything adapted to the car in a week with driving hard and what not.
We will see..
Old Apr 26, 2005 | 02:53 PM
JLee81's Avatar
And the new airbox doesn't have the heat shield underneath it because the bottom part is like the stock. Not 100% Carbon fiber but it's definitely designed for a better flow. So I guess I will have to do shielding again. ^^;;
Old Apr 26, 2005 | 03:43 PM
GrantWinTX's Avatar
CLK 430
Yeah please let us know your impressions of SpeedTuningUSA as I'm due to send them my ECU next week for a chip upgrade!
Old Apr 26, 2005 | 04:22 PM
blackbenzz's Avatar
haters crazy
You should have waited a coupl emore days. The group buy is finally done. Grant, yours came out to 200. Just give Oliver at Speed Tuning USA a call and tell him you are part of the benz group buy and pay. Let me know when you do. JLee81, you only got 7 hp from a renntech intake?????? Post nukmbers for the chip as well cuz I'm also very interested to see the results.
Old Apr 26, 2005 | 11:30 PM
JLee81's Avatar
it was performed after 5days of install. I don't think ECU had enough time to adapt to itself. I bet it makes more hp but there was another car which dynoed right before me and the facility did not have ventilation system, which means that the air was clogged up with smoke. This also might be the cause and my EGS was reset as well at the same time when airbox was installed. The combination of all mods should be incredible wait for the numbers.
Old Apr 26, 2005 | 11:36 PM
Frisco's Avatar
03 CLK500, 04 X3, No 07 GT3RS :(
Group buy?
Old Apr 27, 2005 | 09:47 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Black benz, How much did you say the group buy for the speed tuning chip is?? I would also like to be interested.... I didn't see any posts on this before... please let me know...
Old Apr 27, 2005 | 09:49 AM
jae, I didn't know you got the BBK kit?? make sure that your HRE's will clear those calipers....
Old Apr 27, 2005 | 10:31 AM
JLee81's Avatar
yup its on its way.
Old Apr 27, 2005 | 10:39 AM
JamE55's Avatar
Out Of Control!
JLee
What is your current dyno numbers as of today? How much rwhp are you putting out? Pls let me know or PM me.
Thanks!
Old Apr 27, 2005 | 10:50 AM
JLee81's Avatar
330whp and 340wtq.
Old Apr 27, 2005 | 11:13 AM
JamE55's Avatar
Out Of Control!
Originally Posted by JLee81
330whp and 340wtq.
That's great! Did you really feel a big difference when you got the kleemann headers/downpipes and the lsd? How big of a difference was it from stock? Can i get your impression on that? PM if you like. Just wanted to get your take on it.
Thanks again!
Old Apr 27, 2005 | 02:14 PM
JLee81's Avatar
LSD will be installed on Fri. Installer said 3 hour job so i will talk about that later. Headers and downpipes are great if you want more sound out of your exhaust. ECU will arrive this after noon in 3 hours. Hopefully, I would be able to take advantage of combination of better airflow with advanced ignition timing and PT and WOT remapping, and better exhaust flow from this. I do not fully believe in dyno numbers because there seems to be some descrepencies about the dyno #s and real hp. My exhuast sounds awesome and I get hi-beams on highway whenever I pass by other cars, they only hear a pa~~~~~~~~-shum noise and that's it. When I do not press throttle, its quite inside but you can hear the rumble outside.
Old Apr 27, 2005 | 05:19 PM
blackbenzz's Avatar
haters crazy
You guys didnt hear about the group buy probably cuz I posted it on other benz sites cuz you are not allowed to post group buys on this forum. The group buy has already started and if you want in just call speed tuning usa and tell them you want in on the benz group buy. A 2004 CLK500 ECU upgrade costs $250+shipping+$25 shop supplies. If this is an illegal post just take it down, I'm just tryin to help fellow enthusiasts (I am in no way associated with speed tuning usa)
Old Apr 27, 2005 | 07:37 PM
JLee81's Avatar
I think it's not illegal to have a GB here. I just drove my car.. and I smiled...
Old Apr 28, 2005 | 04:05 AM
blackbenzz's Avatar
haters crazy
I tried posting the GB about a month ago but it was taken down and I was told no commercial posts are allowed on this site. Anyways, how do you heat shield your intake? I would also like to do the same cuz its sits right on top of the engine and i'm sure this heats up the air going through the intake.
Old Apr 28, 2005 | 11:03 AM
GrantWinTX's Avatar
CLK 430
Check this out http://www.thermotec.com/products/full/13500/13500.html
I just bought some from a local dealer who had to special order it. You can get it from www.jegs.com and others. Just take your airbox off, clean it with alcohol, stick this stuff on and trim it and get a few more horses!!
Old May 1, 2005 | 09:19 PM
MR CLK 55 AMG's Avatar
03' CLK 55 AMG
Hey JLee, what happens if you have installed a upgraded chip in your car and you take it to the dealership to get it serviced. How do you know whether or not they reflashed your ECU?
Old May 1, 2005 | 11:23 PM
JLee81's Avatar
Ok.. This is something that I should not mention but I will PM you the info because it involves another company, so it could be an issue, which I do not want to cause. If you are interested let me know.
Other than that, if it is not true then they are scams and I still have nothing to lose because they did not sell what they advertised, I still get coverage from my CC company.
Dyno will tell me the truth.
Old May 1, 2005 | 11:28 PM
JLee81's Avatar
I will still get it serviced fine. They don't reflash my ECU anyways.
If what you worry is the real case, then all other tuning companies who sells chips should be bogus as well, since you don't know what they do with ECU.
Another point is that I am in Boston and there is no tuner for ECU here or any REAL TUNER. So, they are all same to me
Old May 3, 2005 | 08:29 PM
blackbenzz's Avatar
haters crazy
Did you ever get a chance to do a before and after dyno for the chip? ANd has anyone done a before and after dyno with the heat insulation? I'm seriously considering it but does it come off easy if I ever want to sell the renntech intake?
Old Jun 27, 2005 | 11:06 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
My car will be dynoed soon again with the Superchip custom tune.One of their tuner lives here in NY.
