CLK Front Alignment Problems
Old Jun 26, 2005 | 03:58 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
Are any of you having problems with the outside of your front tires wearing faster than the rest of your tires. I took it to MB and they said that it is normal for it to wear that way. Would it help if I lowered the car to change the camber?
Old Jun 26, 2005 | 06:26 PM
reserved's Avatar
clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
Yes!
Although I have an 03 with a Brabus suspension.
I was going to bring it in for an alignment, but maybe thats not necessary???
Old Jun 26, 2005 | 11:40 PM
RJC's Avatar
RJC
Various
Unfortunately all CLK's seem to have this problem and following the recommended tire pressures from MB only makes it worse; the fronts need more air than indicated to help with this issue. A camber adjustment would help but may also negatively effect the inside edges of the fronts even more, though it will help the outside edges. The SL's do not have this problem as their fronts wear perfectly. I recently went through all this with my dealership, they did advise to change the alignment from factory specs and add air to the fronts. You'll also notice the rears will wear much faster in the center than the edges(either outside or inside) so I keep less air in the rears which is contrary to the MB settings but it really helps.
Old Jun 26, 2005 | 11:53 PM
TAMPACLK55AMG's Avatar
how much more air pressure are you adding to the front?
how much less in the rear?
Old Jun 27, 2005 | 12:58 AM
david_101's Avatar
2005 SL65
same problem with my 2002 CLK55. after believing i felt less precise tracking into shallow turns, i saw the wear at rest. quite annoying.
Old Jun 27, 2005 | 11:38 AM
RJC's Avatar
RJC
Various
33 psi cold front 225 45 17
28 psi cold rear 245 40 17
Old Jun 27, 2005 | 01:53 PM
SDBENZ's Avatar
'04 C230 SS
I've got the sam problem on my c230. I've had the dealer do 3 alignments in th 18 onths I've had the car and it still doesn't hold. It will be fine for a few months and then will start pulling to the right. I don't know what the problem is.
Old Jun 27, 2005 | 07:01 PM
RJC's Avatar
RJC
Various
Pulling to the right may not be the cause of the tire wear as even on car's with no pulling the abnormal tire wear is present.
