crazy!my rear axle is locked help meeee
Subscribe
Aug 16, 2002 | 12:07 PM
Hello list-
I ordered a set of 19" HRE rims to put on my 01' clk 55 and they finally came in and I took the old rims off the car and put the new HRE's on the car. I got in to drive the car gave her some gas and nothing ! the axle seems to be locked. I looked for constrictions and rubbing but found nothing wrong. The tires clear the wheel well.
I put the car in neutral to see if I could roll the car and same thing, it rolls very little forward and reverse but then locks up. If I put the car in drive, the car will not move forward, same as with the reverse.
Is it possible I somehow damaged the tranny? I did not torque the wheel lugs on with the car in the air, I tightened the lugs after the wheel was firmly planted on the ground. I used a jack under the car, not the mercedes jack and I lifted the car via the rubber grommets near the jack openings on the car.
Any immediate help greatly appreciated!!!
Reply 0
Aug 16, 2002 | 12:33 PM
Weird, Did you release your hand brake?
Reply 0
Aug 16, 2002 | 12:43 PM
of course
yep
Reply 0
Aug 16, 2002 | 01:15 PM
I hope they didn't give you the longer wheel bolts. With longer wheel bolts, the bolts will hit and jamp the rear hand brake pads.
Reply 0
Aug 16, 2002 | 01:16 PM
I had the same problem when I first mounted my HRE's:
Check your lug bolts! You should have gotten two different sizes...the ones in the rear need to be shorter than the fronts or else they contact and can interlock with the parking brake mechanism...check it out carefully for any damage also....I had to get new ones sent to me and even then had to grind them down a bit...May be you put some of the shorter ones on the front? Check the lengths carefully...Good Luck!!!
Reply 0
Aug 16, 2002 | 01:21 PM
lug nuts
I was just using the lugs that came with the factory AMG rims. Is this wrong? I cannot see the lugs interferring with anything but I will check that out.. The factory ones wont fit ? where to get new lugs bolts from
Thanks all !
Reply 0
Aug 16, 2002 | 01:25 PM
in addition:
when I got in the car and put it in reverse to get out of the garage, I felt that the car would not move, because when I shifted it into reverse, the car stood still.. I gave it a tiny bit of gas and still nothing . so I put it into park and left it alone.
Im not sure of the lugs, but it makes sense that something is hitting since there is a little movement forward and reverse. I guess if it were the axle itself, I would have no movement. Also in neutral the car only still moves slightly forward and slightly in reverse.
I think Im screwed. Should I put the original rims back on and take to the dealership? Or does anyone know what size lugs I should get? The HRE rims are 19" 448R 19X8 front and 19X9.5 rear
Reply 0
Aug 16, 2002 | 01:43 PM
This may sound stupid,
But why don't you just put your stock rims back on your car to see if it moves
Then if it does then you can work from there. :P
Reply 0
Explore
Aug 16, 2002 | 01:54 PM
kind of said same thing
If you noticed in my post, it says the same thing .Its just Im sitting here at my day job wondering what the heck is wrong with it, and I want to get home and figure out the solution.
Puting the stock rims back on is a chore in 110 degrees, so if there is something that Im overlooking, Id rather look at my options. If its lugs, I can go out buy the lugs and put them in without having to put the stock rims back on
Reply 0
Aug 16, 2002 | 02:19 PM
What are your plans for your old wheels, assuming you get this sorted out? I might be interested if you are selling your old ones for a good price, I am in AZ also.
Good luck - John
Reply 0
Aug 16, 2002 | 03:07 PM
HOLD IT! STOP!
The stock bolts for AMG rims are about 3/4" too long for your HREs.
They should have sent you new bolts. Then, the new ones should only go in about 4.5 turns before seating.
If it rolls but still get clicking, they're still too long.
Reply 0
Aug 16, 2002 | 03:15 PM
actual size
so is there a correct size that I need to order? I dont think this hit and miss thing is going to be fun. I think you are right. I spent $4,500 for these rims. They should have sent me the proper lugs or offered them to me as an option.
any ideas where to get lugs fast and the size that I need for my application ?
Reply 0
Aug 16, 2002 | 03:42 PM
As we keep saying...No you should NOT be using the stock bolts! Call up HRE or who ever you ordered the wheels from and get them to send you a proper set of lug bolts...like I said I went through the exact same problem...they Fedexed them to me...i don't have them with me or I would get you the measurements...techbike is right...and as I said before we still had to grind them down a bit before they quit catching the brake hardware.
Reply 0
Aug 16, 2002 | 03:47 PM
I had the same problem when I first mounted snow tires on my 2000 E430. It was because I used the lug nuts with the summer tires which are about a half inch longer than the lug nuts that go with the winter tires. I'm sure that's the problem based on what you are describing.
Reply 0
Aug 17, 2002 | 12:48 AM
Pcglobal,
There's is a simple way to check this. Just jack up the rear (both side) release the and brake and put the transmission in "neutral" then spin the tires. It should turn. If not, then loose u all the wheel bolt and turn them again.
Reply 0
Aug 18, 2002 | 04:22 PM
Re: actual size
Where is the world did you order your wheels? $4500 and no lug nuts or bolts? When i got HRE 540RDC's it came with the lug nuts and bolts. That's really weird that your order did not came with those?
Reply 0
Subscribe
Currently Active Users (1)
