Anybody have a front mount for their s/c?
However, I think any good custom engine shop should be able to do a good port/polish valve job on the heads. I would personally be more comfortable dropping just my heads off to a shop rather than have them do the entire teardown. That way if it's a mainly dom. shop there is nothing forgiegn about the work they are performing. Defenitly check out the E55 section and read up on VRUS's posts. He can tell you ALOT more than I can. He has a brand new one going over his head work. I believe he uses a shop that dose mostly domestic work as well. Some of the best around here do manly dom. work. The shop that dose work on my car builds Supra motors at that. I will use them for my head work if it happens.
Vrus is expecting to pick up a conservative 40-50hp with the head work.....not sure on the cost though.
When you take off your new front bumper to replace it with your Carlsson setup you'll see that there's a small radiator that's part of your blower's cooling circuit - where the water that soaked up the heat inside your S/C manifold gets cooled back down before circulating back through your S/C. It's that rectangular black radiator you can see in this pic from DragonAMG's setup:
On your setup, that might already be mounted in a way that it will will show through your Carlsson, but I think that the look you're after is probably a silver looking larger unit. Maybe you can go aftermarket on that radiator and end up with something that's more the size and color you're after to stuff inside your Carlsson's mouth... that way people might at least have a clue that they're about to get slaughtered
here are some pics of my set up
P.S. donsnt the kleemeen S/C come with a separate cooling system?
so the cooling is seprate but it is tied into the engine cooling system?
The radiator I was referring to in my prior posts is not the engine's radiator - it's a separate radiator that's part of the S/C's independent coolant circuit. The black rectangular one pictured in the post depicting DragonAMG's setup.
But I'm no expert on Kleemann - I only know what I know because Cory @ Kleemann USA will answer even the most mundane question about Kleemann thoroughly and in record time... and I've asked quite a few.
BTW - the workmanship on your reservior tank looks amazing - just like the quality of that intake you made.
coolkarlskiC43- I picked it up yesterday and for now the 430 will be a daily driver.
2precise- Thats a nice setup but I would want the "ricey" front mount. I think it would look great behind the large Carlsson RS front opening.
I already have a bunch of kills. It was a long drive from Boston. Kills so far = New S4, C6 vette, bunch of M3's
, CLK430, E500, and some pickup truck
So far I havent found a worthy opponent. I want to race a ferrari 360. Its very hard to put the power down without traction control intervening. I'm not ready to keep the t/c off because I tried it once and punched at 30mph and the car went sideways
The car goes form 80-120mph in the blink of an eye and it never lets up. I'm loving the car so far.
oh ok... wonder why they would do that...should keep it completely seperate, cant see how hot coolant will keep air cold...
Thanks... I designed it so it mounts onto factory fastners, so there is no drilling and butchering..works and look awesome.
