Forged internals?
Old Mar 26, 2007 | 11:23 AM
blackbenzz's Avatar
haters crazy
Forged internals?
Who knows for sure what parts of a W208 CLK55 are forged inside the motor? I've heard a whole bunch of different answers. Anyone that knows for sure please chime in. Forged pistons, rods, etc?
Old Mar 26, 2007 | 11:51 AM
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
blackbenzz, I can't meet your standard of proof (sorry) and you may have already heard this, a few of the 2001 CLK55 car magazine articles described some of the engine parts this way:
"The CLK AMG is powered by a hand-assembled 5.5- liter V8 engine. The hardware list reads like that of a race care: super-stiff forged billet steel crankshaft, forged, weight-matched connecting rods and pistons, lightweight AMG-specific camshaft churns inside the pressure-cast aluminum block of this chain-driven single overhead-cam V8......"
If the article writer was correct then the crankshaft and connecting rods and pistons would be forged.
Old Mar 26, 2007 | 11:54 AM
blackbenzz's Avatar
haters crazy
Than you ashutt! I am very impressed. I was thinking about doing forged internals but it doesnt seem neccessary since they are already forged!
Old Mar 26, 2007 | 01:33 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
AMG built one hell of a LUMP!!! All the factory Benz mechanics I have ever spoken to say they have never seen one fail and they are bullet proof.
-O
Old Mar 26, 2007 | 04:38 PM
Charles Joseph's Avatar
2002 CLK55 Kleemann
-O
Want to bet? I have a CLK55 that just today is having its engine removed due to no compression in the #6 cylinder. NO ENGINE IS BULLETPROOF! Parts fail and there is nothing you can due to eliminate it.
Old Mar 26, 2007 | 04:51 PM
Schiznick's Avatar
SL65, E55T, Pending S65
Your car is supercharged isn't it? Has any stock 208 CLK55 engine failed?
Not saying that it wouldn't or couldn't as any engine can but no one has posted one here......
Old Mar 26, 2007 | 04:53 PM
rsr911's Avatar
Charles,
Sorry to hear it. Of cource there have been failures but they are few and far between.
-O
Old Mar 26, 2007 | 05:20 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Ted Baldwin or somebody is doing a motor rebuild and turbo project on a 5.5l motor in the W211 E55 thread Ahmad. Do a search in there because I can't exactly remember the thread. That person will know or i can find out from my mech Jeffrey tonite!
Old Mar 26, 2007 | 05:23 PM
ProjectC55's Avatar
I believe these facts are 100% correct.
Old Mar 27, 2007 | 05:55 PM
Ted Baldwin's Avatar
300ce
...........the problem is not forging. The cylinder walls are extremely, I mean really really extremely thin. The rods are very thin. The cylinder walls have a special coat that is incompatible with aftermaket rods and pistons. As a result you cannot just get upgraded pistons and connecting rods. Best to stay with your engine as is, or rebuild everything including the cylinder walls.
Ted
Old Mar 27, 2007 | 07:24 PM
blackbenzz's Avatar
haters crazy
Ted
That sucks. Thanls for the info
Old Mar 28, 2007 | 12:41 AM
ProjectC55's Avatar
Ted
But Ted is'nt there someone in the W211 E55 forum that is doing a heavy motor build upgrade to his E55 with bigger bore blck,aftermarket ,after market oversized pistons,bigger valves with ported head ETC? Not too sure if your 100% correct but I could be wrng!
Old Apr 10, 2007 | 08:56 AM
300ce
..........Yes. The pistons and the cylinders have a nicoseal coat. You can bore the cylinders. That will get rid of the nicoseal coat. You can then get larger after market pistons which do not have a nicoseal coat and you are good to go. You cannot just get non nicoseal coated after market pistons and use them with your stock cylinder wall. I have taken apart my W210 engine block and the cylinder walls are extremely thin. The oter wall of the cylinders are no reinforced. Boring it to get a larger displacement for NA maybe ok, but for FI will be crazy. Maybe the W211 block is different.
Ted
Old Apr 10, 2007 | 05:53 PM
NitrogenBalance's Avatar
none
What about using the 4.3 or 5.0 M113 to build up?? Using the same M113 block and having a smaller discplacment would usually mean smaller cylinder bore and thicker walls correct?? Which would leave more room for opening things up?? I'm no expert, just a thought.
