Suspension upgrades???
). I guess I need to make a custom brake duct unless there is one already available.I am pretty happy with the straight line performance and I was doing very well at the MBCA event at Summit Point but I want to get rid of the understeer as much as possible.
Thanks for any suggestions
The agressive camber is hard enough on your tires.
Stiffer rear sway bars will help get your car to rotate better into the corners.
Also you need to play with tire pressures.
For track I run 42lbs cold front and rear. Then play with it hot add a little more to the rear and reduce the front. I am talking 2 lbs each way.
The harder the rears are the faster they will start to slide giving you
oversteer and reducing understeer. Same principle with stiffer sway bars alows the front to roll and transfer weight for better grip.
You can play with this for ever. I ahd to adjust my WRX track car every time I went to the track. Temps and track condition changes even hour to hour might require adjusting.
A side note. Understeer is not a totally bad thing. Most cars are set up with it from the factory. It is much safer and slower than having a car set up to oversteer. It lets you know you are getting close to a crash with out snapping your head off when it lets go and throws you into the armco guardrail or a tree.
Look at the stance of the cars in the 3 post previous to mine, they are much more level. Like I said, just an observation, for what it's worth.
jrcart- I have the KW v.2's and the rear is set as far down as it will go
This is how the car sits now (missing black mesh in the bumper in the pic). Its pretty even
Don't believe me? Ask MachC5 on his wheels.
The sticky is in Classifieds. Heck, I'll make a thread here as well.
Any pics/vids of the MBCA event?
Will also tell you what your weight bias is.
I have some pics on my home ocmputer and a couple crappy vids. I posted this one in the other thread http://www.youtube.com/watch?v=_tieZ-raTN0
rsr911- I will look into that. I just realized I was only running 32PSI of pressure in my tires!
I just had tires mounted and balanced 2 days prior and I forgot to check!
Really though, that is one of the nicest looking 208's I have seen.
This may help you figure out the correct tire pressure for each corner (no, they won't all be the same).
Awesome!
Edit: ok so the H&R sways are 28mm in the front and 18mm in the rear. What are the stock ones?
What your friends said in regards to tires is absolutely true.
