04 CLK55 shaking when idling
Old Jul 10, 2008 | 05:09 PM
sc55's Avatar
CLK55
Hello everyone. I have 2004 CLK55. I feel the car is a bit shaking when it is at idling. Is it normal?? If not, does anyone have similar problem??
Old Jul 10, 2008 | 07:33 PM
Jaki's Avatar
E55 AMG + Mustang GT
Check your spark plugs.
Old Jul 10, 2008 | 07:38 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
If the rpms are stable its not the plugs. Could be the engine mounts are shot?
Old Jul 10, 2008 | 07:53 PM
ohlord's Avatar
Ditto
plugs would throw a misfire code generated by the cps.P0300 code range.
Check motor mounts per Jon and also trans mount.
You may want to scan for pending misfire codes even if they have not shown up yet with your obd2 scanner.
ohlord
Old Jul 10, 2008 | 08:50 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Air mass sensor might also be a probability.
Old Jul 10, 2008 | 09:09 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
+3 for motor mounts.
Old Jul 10, 2008 | 09:16 PM
ohlord's Avatar
Maf
will throw codes also if out of range or failing.
go to http://www.harborfreight.com/
if you have one near you and pick up the 94169 obd2 scanner for $60 and plug it in to be sure no pending codes show up,then inspect the above mentioned mounts.
http://www.autohausaz.com/search/pro.../Motor%20Mount
trans mount 18 bucks
ohlord
Old Jul 10, 2008 | 09:19 PM
Tony Yeung's Avatar
CLK 55 AMG
I had the same problem. Took it to 2 dealerships and talk to 2 foremen, they both said it was normal for AMG vehicles to idle rougher than normal Mercedes cars. The last dealership said he would increase the idle 75rpms to help it out. Motor mounts were fine and no codes.
However, from the information I gathered here it could be the MAF sensor or the air filters. I tried pushing the dealerships to replace them but it wasn't working. I plan to do it myself in the near future.
-Tony
Old Jul 10, 2008 | 09:45 PM
ohlord's Avatar
Filters
16 bucks each at autohausaz.com clean your maf with crc brand maf cleaner for 6 bucks,inspect his mounts.If shaking enough at idle to bother him it is more then the off idle balance issue in the 55 engine.
ohlord
Old Jul 15, 2008 | 02:55 AM
sc55's Avatar
CLK55
Thank you for the info guys!! I will check those out.
