10w-30 Mobil One Synthetic.
Old Jun 13, 2009 | 12:46 PM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
I did a search, and really found nothing I was looking for.
My check oil level light was on, and it was a tad low.
I did not want to mix different oils as I could not be certain what oil was in there. So I decided to get an oil change done.
Noone had 0w-40 in stock,
So I popped open the manual and there is a chart saying as long as it doesn't go below -20 degree by my next oil change I can use 10W-30.
So I bought two cases of 10w-30.
Finding a filter was a pita. Didn't want to use the generic. So I ended up going to the dealer. Got the filter and asked if they had 0w-40 .Don't have individual cases/quarts. It's in drums.
They said make sure you use 0w-40 the parts people said. I said the factory approved service products manual states that it is okay for 10w-30. They replied i'd check with serivice. I have never heard of that.
So I did, the service writer was with a technician, and he said 0w-40 or 10w-30 is fine.
However, I changed it yesterday with 10w-30 and I'm paranoid maybe he was just blowing me off.
Any input would be much appreciated.
Old Jun 13, 2009 | 02:53 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
I would never use any oil other than the recommended 0w 40 or 5w 40. AMG engines are very strong but 'sensitive' (for the lack of a better word). Using the 10w 30 just this once might not be so bad but I would strongly recommend that you find some 0w 40 and keep it stored away for times like this...the last thing you need is for your engine to start knocking etc...could cost a nice chunk of change to get it fixed. Just my 2 cents. Good luck and drive on
Old Jun 13, 2009 | 04:53 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Ive been using 10-30w Castrol Synthetic for the last 10k miles. Changed it every 5k. Never had a knock and car runs fine.
Old Jun 15, 2009 | 09:38 AM
Nachtsturm's Avatar
I went and just swapped it out with 0-40w Mobil One. Should have just hunte d for the oil to begin with.
Only place that had it was autozone. Had only 9 quarts of it.
Old Jun 15, 2009 | 06:31 PM
fourml8r's Avatar
2005 CLK55 AMG CABRIOLET
10W-30 is perfectly fine. both that oil and the "Recommended" 0W-40 will meet the same classifications. The difference is the "Weight" of the oil which in laymans term is its' abaility to flow in colder weather (Hence the -20 statement). Caveat is that you are using the recommended full synthetic.
As far as filters, you're wasting money by getting it at the dealer. You can find them online easily for much lower prices than the dealer. Check for Mann or Mahle filters, they are OEM suppliers to MB. Use the better "Fleece" filters rather than the cheaper paper filters.
For future info., mixing grades of oil is not a problem, you'll just end up with something inbetween the 2 weights of oil. And if you're only adding 1 qt. of a different weight to 7 qts. in the car already, the actual difference is low (Figure ~10% change). That will not impact you're car at all.
Old Jun 15, 2009 | 08:42 PM
Nachtsturm's Avatar
I only paid15.00 for the MB filter. FIgured this wasn't that bad.
Thanks for the advice though. Didn't want to chance it. So I blew 50 bucks in oil. At least I have peace of mind now. lol.
Old Jun 15, 2009 | 08:58 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Does the 10W30 you bought have the MB spec 229.5 on the label? If not I would be hesitant to use it and I think you're wise to have gone to the certainly recommended 0W40. I think some other manufacturers (Castrol comes to mind) offer some different weights that have MB approval. On the other hand, one school of thought is practically any oil is OK to use as long as it's changed at the "proper" intervals and the filter is changed.
Old Jun 15, 2009 | 11:02 PM
JYO's Avatar
JYO
1999 E 320 (sold), 2015 AUdi S5 (sold) 2005 CLK55 Cab, 2016 Honda Pilot Elite, 2011 Jaguar XF
I've been buying the 10w30 from Costco (for my E320) for awhile now and no problems. i think it works out to about $6/qt I think. My locla MB mechanic said it's fine.
Old Jun 16, 2009 | 01:23 AM
MarcusF's Avatar
2002 CLK430
There’s a long winded technical answer, but I’ll try to be brief. Lubrication is dependant on flow. Viscosity, as it's measured in motor oil, is a measure of a fluid's resistance to flow, or it's "thickness". That "thickness" is quantified in centiStokes (cSt - Stokes Law for Friction). Motor oil thickness is temperature dependant. The normal operating temperature for motor oil is 100°C. Using the Mobil1 product data sheets available at the Exxon Mobil website, you can see the specs for Mobil1 0W-40. At 100°C, Mobil1 0W-40 is 14 cSt. I’m going to *guess* MB powertrain engineers built tolerances around that number. If the motor oil in every M113 was always in that range, there would be no wear, and they would outlive most of us. Unfortunately, when the engine is off, oil cools. At 40°C, Mobil1 0W-40 is 78.3 cSt. That’s a little thick for good lubrication, which is why people are told to stay off the gas with a cold engine. I wouldn’t use a motor oil that doesn’t meet MB spec because *I think* there’s a good chance that it’s either too thick when cold, or too thin when hot. Mobil1 5W-40 is an example of what I’m talking about. Mobil1 5W-40 is over 100 cSt at 40°C.
But hey, owners should use whatever they feel most comfortable with.
Old Jun 16, 2009 | 11:25 AM
Nachtsturm's Avatar
So you say use 5w-40 over 0-40?
Man I hate being a newbie. I spent too much time in the american V8 scene.
Old Jun 16, 2009 | 01:06 PM
MarcusF's Avatar
2002 CLK430
No, I use 0W-40. For an M113, I want the oil as close to 14 cSt as I can get it (and here's they key) - at all times. I know when cold, the oil will be quite a bit thicker than 14 cSt, but 78 cSt at 40°C (which is what 0W-40 is), is much better than 100+ cSt (which is what 5W-40 is) at the same temperature.
Old Jun 16, 2009 | 02:56 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
use 0w-40
Old Jun 24, 2009 | 12:16 PM
iblaho's Avatar
My dealership uses 5w40.
The work order says they put in a Bosch original paper filter for a 2006 model - I have a 2007. I'll bring it up next time, since I'm supposed to have a wooly filter.
Factoid: I looked online for an OE fleece filter, found it at Autozone, and it was paper. New and improved paper???
A private mechanic told me he'll get me a real fleece filter if I give advance notice.
Experience: I went to the Oil Changers in an expensive neighborhood and asked for Mobile 1 0w40. I caught the tech putting in 10w30. He said it was all the same. Maybe it is fine, but I didn't like being lied to. Won't go back.
Kragen and Walmart AND Autozone carry Mobile 1 0w40. Availability is the thing. Usually $6.99. The dealership charges $6.40/qt.
Old Jun 24, 2009 | 01:44 PM
M-bENZ's Avatar
Corrolla
0w-40 for me too.
Andy
Old Jul 16, 2009 | 07:40 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Two out of the three dealers in Phoenix use 5w-40 normally. On my first service I went along with it but had noticeable valve noise for the first half mile or so when temps dropped below 60 deg F.
The second time around I insisted on 0w-40, but with lows in the high 80s I can't tell if it made any difference.
Old Jul 16, 2009 | 03:03 PM
Eurosport's Avatar
monowiper
mobil 1 10w-30 is too thin for german cars...it is good for my generator though lol
Old Jul 29, 2009 | 12:18 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
Same here in Southern California. Around here 5w-40 Mobil 1 is what I have seen them use.
Old Jul 29, 2009 | 11:33 PM
iikillali's Avatar
CLK55 AMG
i got tons of 0-40w selling~ if you in North Cal and wanna get some pm me~ i'm selling $45 a case 6qt per case
Old Jun 22, 2015 | 02:42 AM
Khan 55's Avatar
2004 CLK55 AMG W209
really lost with this oil usage. Have read up old post last week on page 50 some odd here. 3 page article/post on oil. So yes 0W40 Mobil1 for an M113 engine. I was able to check with Porsche and found they sell a litre of it at R180 approx. $16 a litre. They told me they soon will be moving to Motul oil which will cost R110 a litre approx. $9
So I buy the Mercedez Benz 5litre oil which complies with the standards for me AMG motor. The thing is this is South Africa. We don't experience lower than 0 temp here. Hell I never seen anything below 5 either and this is Celsius not Fahrenheit. So I buy the oil and the guy tells me its 5W30 motor oil. made in Europe, its Mercedez oil. Yes the requirement/standard for Merc oil is correct BUT, I see it is Synthetic oil and not Fully Synthetic. Should I ask for my refund or in my case will exchange it for tranny oil or a tranny filter. I bought 10litres of this oil which cost me approx. $48
The salesman told me they use it in the AMGs in the workshop. Its only in the workshop when you do a service that they will use Mobil1 0W40 oil and the B service quote was approx. $540 just for filter and oil
Am I safe using Synthetic oil or should I use fully synthetic?
I don't want to put my engine at any risk especially since it has almost 240 000km on her.
From what I read above, they say to stick with 0W40 Mobil1. What do I do end of year when Porsche now stocks Motul and no longer Mobil1?
