Metal Core high flow cats now only $75 on ebay....
Old Sep 20, 2009 | 10:30 AM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Hey guys,
Found another seller on ebay selling the same 300-cell metal core high flow cats for only $75 shipped each. If you haven't done high flow cats yet, now would probably be the best time to do so for only $150 shipped for the pair. Always trying to bargain hunt for you guys .
http://cgi.ebay.com/ebaymotors/Thund...Q5fAccessories
Hope that helps.
~AMS~
Old Sep 20, 2009 | 10:55 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
i doubt there is much of a difference between the 200 cell and 300 but if there is what would it be? and which ones would be the best to go with?
Old Sep 20, 2009 | 01:05 PM
AMG
difference between 200-300cell may be 1HP, its really not worth considering the difference. The 300-cell metal core cats still make great power
Old Sep 20, 2009 | 01:10 PM
MARTYMAR's Avatar
07' IS 350, 08' E550
Originally Posted by AMS Performance
Hey guys,
Hope that helps.
~AMS~
I just had my stock cats changed at 80k miles under warranty. These AMG's eat up cats like crazy. I want to pull the trigger and get these but I'm having a hard time finding a shop that will install them for me. The other issue I'm having is the CA smog laws. Will I be able to pass smog with these cats?
Old Sep 20, 2009 | 06:52 PM
MarcusF's Avatar
2002 CLK430
Speaking from experience - as long as the substrate holds up, you'll pass with aftermarket cats. My name-brand-supplier's cats were dead in two years, but YMMV. The tough part will be finding someone in SoCal to install cats that don't have a CARB sticker.
Per the California Air Resources Board website the following cats are legal for OBDII Mercedes Benz’
  • Car Sound (Magnaflow) 46000 series cats for 1996-2000
  • AirTek (CATCO) 410000 series cats for 1995-2002 (can't find them in the CATCO catalog)
  • Miller Catalyzer Corp 12000/11000 series cats for 1995-2004
  • Valina (CarTex) 12500 series cats for 1996-2000.
None of those have a metal substrate. Other than that, you’ll need a *friendly* SoCal muffler shop. Anyone want to start a private PM chain? Don't post it in the open or the *friendly* shop will probably get closed. Another option – Vegas. Perhaps an MBWorld poster from Vegas can make a shop recommendation for those willing to drive out on Friday night, get the cats installed Saturday morning, and then wrap up the weekend at the tables.
Old Sep 20, 2009 | 08:54 PM
MARTYMAR's Avatar
Thanks Marcus good info. How many HP gains can I expect from changing the cats? 10?
Old Sep 20, 2009 | 11:18 PM
AMG
Hello Marty,
The cats are OBD2 compliant and 49 state legal rated up to 5.9L. Honestly though there will be no way in hell they could ever tell it wasn't legal. Also metal core cats last longer, fire up quicker, and do a better job of cleaning up emissions. Only downside is they cost a bit more. As long as you have real secondaries they won't bother you.
On a stock car 300-cell metal core cats will make 10HP/12TQ on dyno, on a modded car they will make more. Hope that helps.
~AMS~
Old Sep 21, 2009 | 09:45 AM
FatTony001's Avatar
CLK 55 AMG 2005 and CLK 63 AMG cab.2007 - 2009 EVO - 2013 ML63 AMG - 2018 G63 AMG
Is the new Cats you found the same quality then the old one you suggested?
New: http://cgi.ebay.com/ebaymotors/Thund...Q5fAccessories
Old: http://cgi.ebay.com/ebaymotors/High-...=p4506.c0.m245
On looks only, the old one suggested look cleaner... better... no?
what do you guys think?
Old Sep 21, 2009 | 11:40 AM
M-bENZ's Avatar
Corrolla
ok so are those cats only applied to CLK55 AMG ? Can I fit that on my ride too (CLK320) ?
Andy
Old Sep 21, 2009 | 12:49 PM
AMG
They are same brand, just cheaper retailer. I wish I had found them earlier but they just popped up recently so now I'm recommending the cheaper of the two (obviously). Hope that helps.
~AMS~
Old Sep 21, 2009 | 12:51 PM
AMG
Andy
Andy,
They are universal so they can be applied to pretty much any car. The gains on the 55 AMG are much greater though, you may only pick up a few HP on your CLK320, but if you want more sound then its a possible way to go. Your CLK320 though has more restriction in it so there are other bottle necks in the system.
Old Sep 21, 2009 | 03:04 PM
ashutt's Avatar
2005 SL600 by SPEEDRIVEN
Inlet & Outlet Size for 2001 CLK55
Any idea on the inlet outlet size for a 2001 CLK55, which will be helpful in ordering these. Thanks in advance.
Old Sep 21, 2009 | 03:54 PM
Jason1000RR's Avatar
women crazy.
How does it effect exhaust tone?
Old Sep 21, 2009 | 04:01 PM
AMG
2.5" inlet/outlet will do just fine for W208 CLK55 AMG. Any muffler shop will use any extra straight piping if necessary.
Old Sep 21, 2009 | 04:03 PM
AMG
It will improve the exhaust tone but making it deeper and more meaty without any rasp or etc. Its not a huge transformation but it is noticeable after 2 weeks. The key thing is it maintains the OEM refined exhaust note during daily driving and is louder under WOT.
To truly wake up the car you would need a set of our headers in conjunction with the high flow 2nd cats. Those will really wake up your exhaust note (even with stock resonator & muffler, which are recommended to be kept in place).
Hope that helps,
~AMS~
Old Sep 21, 2009 | 04:38 PM
MarcusF's Avatar
2002 CLK430
My 430 has a theoretical flow capacity of 451 CFM at 6000 RPM. Because of the CLK exhaust design, each cat can only see half the total capacity. Based on that, to see increased HP and torque across the band, with a 10 HP improvement at peak, my current cats would have to flow less than 225 CFM. Hmm . . . . . 225 . . . . . . . by comparison, I know of one Hyper Flow cat that flows 580 CFM. I could be wrong, but I wouldn’t expect much.
Each CLK320 cat only needs to flow 170 CFM.
Each CLK55 cat needs to flow 285 CFM.
Anyone have a before/after dyno where the reset was done before BOTH runs? In the past, it's been demonstrated that HP can be increased on a dyno by untying one's shoes (and doing the reset ), so the reset is kind of necessary.
Old Sep 21, 2009 | 05:27 PM
M-bENZ's Avatar
Corrolla
Andy,
Any idea where is my second cats at ? same location of CLK55 W209 ?
Andy
Old Sep 21, 2009 | 06:38 PM
women crazy.
Hope that helps,
~AMS~
Good ta know, thank ya! Gotta buy them in pairs, though?
Old Sep 21, 2009 | 09:53 PM
njzprettyboy's Avatar
R8 V10
How many would you need for a 500 motor? It has a single muffler. Would this make the sound of my exhaust any deeper?
Old Feb 6, 2010 | 03:02 AM
user 76208202's Avatar
CLK550
are these primary cats or secondary? can i swap these with my primary on my CLK550 (i believe my primary is on my headers?)
Old Feb 6, 2010 | 06:48 PM
GiZzO's Avatar
CLK55 / E350 Coupe
Psst I just PM'ed you a shop in LA.
Old Feb 6, 2010 | 07:25 PM
AMG
secondaries are the ones you should replace, they are simple & easy... primaries are much more difficult challenge on most cars and its best to leave them alone as much as you can. buy them in pairs.
Old Feb 6, 2010 | 08:13 PM
Thericker's Avatar
V12-Biturbo
The SL600/65 only come w/huge primary cats
I've swapped a pair of these in 3" sizing along w/custom Down-Pipes from turbos, relocated O2 bungs, NO check engine lights & sound is wicked Thank you for posting the info...
Been on a few months now...
Old Feb 6, 2010 | 08:29 PM
CLK550
I don't beleive 550's have secondary cats (at least my clk550 doesn't. are primary's the ones right under the headers? because that's the only cats my car has at the momment).
Old Feb 6, 2010 | 10:23 PM
s4avt's Avatar
'03 CLK 55
So, what if I go with Kleemann headers that comes with straight pipe. can I still get race get with Kleemann headers?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
