I get this minor vibration around 40mph + and gets weaker up in 60
Old Mar 1, 2010 | 12:01 PM
s4avt's Avatar
'03 CLK 55
Everytime I drive around 40mph, I get this minor vibration.
and it gets weaker up in 60.. but not completely gone.
I thought it was wheel balance, but it is still there after I balanced my tire in
Disount tire. So I took it to the dealer and described them what's going on, and they said it gotta be wheel balance, but I refused to do it at the dealer because I know how much they are gonna charge me : )
Do you guys think it is Discount tire who didn't do there job well? or something els.... I can certainly take it back to Discount tire and redo the balance since they offer lifetime balance..
Old Mar 1, 2010 | 01:30 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
FWIW, I had my SL tires balanced 5 times at Discount and they still could not get the shake out of it. I gave up on tire shops... Take it to MBL and talk to Garrett. Had MBL balance the tires and that took care of the problem.
This weekend I noticed a rear tire out of balance at 185mph so I'll take it back to the dealer to re-balance ;-)
Old Mar 1, 2010 | 01:36 PM
Coupecrazy's Avatar
2001 CLK55 AMG
If you feel it through the steering wheel try looking at the steering damper. Cheap, and easy to replace. Also the bearings may be loose. I had a slight vibe at 40mph when I bought mine, and it turned out to be the front bearings. I checked them, and just ended up replacing them. Took care of the issue.
Old Mar 1, 2010 | 02:04 PM
Nachtsturm's Avatar
2015.5 Volvo V60 Polestar
Could be bent wheel as well.
Old Mar 1, 2010 | 02:46 PM
s4avt's Avatar
'03 CLK 55
Sounds like that's what I am gonna do, I told dealer that I took my car to discount, and they said take it somewhere els..
Old Mar 1, 2010 | 02:47 PM
s4avt's Avatar
'03 CLK 55
I can feel it the actual whole car.. not just steering wheel... but I can feel in on steering wheel as well.. I will double check on damper
s4avt's Avatar
'03 CLK 55
I doubt it... if the wheel were bent, they couldn't even make the wheel in balance and would have told me
Old Mar 1, 2010 | 04:33 PM
suicidal4life's Avatar
2001 E430
The way you were talking about your wifes driving a bent wheel might be possible.
Old Mar 1, 2010 | 05:00 PM
BeltFedBob's Avatar
Haha, I think I heard that too on Saturday!
Old Mar 1, 2010 | 05:34 PM
s4avt's Avatar
'03 CLK 55
Oh.... Snap!!! May be its time to have a new wheels : )
I will double check.. very possible
Old Mar 1, 2010 | 05:50 PM
BeltFedBob's Avatar
Mike@Cascade Wheel in Lynnwood is the place to go to have you wheels fixed.
(425 778 4672)
Old Mar 1, 2010 | 07:13 PM
Chappy's Avatar
AMG
A few suggestions...
Lower control arm bushings
Motor mounts
Driveshaft or flex disc
Tire(s) out of round
Alignment
Good luck!
Old Mar 1, 2010 | 11:57 PM
s4avt's Avatar
'03 CLK 55
Thanks, looks like there are more than just few things to check..
but I rather drive it smooth : )
Old Mar 2, 2010 | 10:48 AM
AMG10's Avatar
Don't trust tirer places I had my tires put on that I bought online at a Goodyear tire place.
I drove the car out and new right then that they did not balance them right. I took them to my place of work and sure enough 3 of the 4 were out I did the 3 and all is good. So nerver trust anyone.
Old Mar 2, 2010 | 07:09 PM
krispyw208's Avatar
02 clk 55 amg
If you go to discount tire, tell them you want the tires balanced "alloy 2". I used to work for discount/americas tire a long time ago. This is thee very best balance anyone can do... If the shake is in the steeing wheel, then most of the time its balance. If the shake is through out the whole car... I'd bet something else is wrong... When they put the rim assembly on the balancer, ask them to watch personally for any kind of bend also. It is easily noticable when the rim and tire spinning at that rate to see any kind of bend as the wheel will "wobble". Hope this helps.
Old Mar 2, 2010 | 08:31 PM
Stiggs's Avatar
2003 CLK55
WOW...someone else with my problem!
I have a vibration that comes on right at 40-45mph then pretty much disappears above that speed. I feel it in the drivers door and the steering wheel so I would say its the whole car. Had all the tires balance and checked for bent rims at the dealership. So that wasn't the problem.
They had the head tech guy drive it and he thought it felt like the driveshaft might be out of alignment? He said something about the transmission mounts might be colapsed and I think he mentioned a flex disc being busted as well. This is just what he thought....no clear cut evidence.
All I asked him was "is it expensive to fix?" and he said yes and I said "well, I'll live with a vibration at 45mph." lol
I know I have to get it fixed sooner or later but I don't know if I want them tearing up my car searching for this vibration.
Let me know what yours ends up being.
Old Mar 2, 2010 | 08:33 PM
s4avt's Avatar
'03 CLK 55
That's not a good new Stigg,
Since I have motor and transmission mount on my hands
I will replace them first, and lets go from there : )
Old Mar 2, 2010 | 08:34 PM
s4avt's Avatar
'03 CLK 55
Is it hard to replace drive shaft or flex disk?
Old Mar 2, 2010 | 08:43 PM
Stiggs's Avatar
2003 CLK55
Probably. I think thats why the guy said it would be a bit of money because they would have to take stuff apart to see whats wrong. I don't really remember what he said so I may be wrong.
Old Mar 3, 2010 | 12:39 AM
MarcusF's Avatar
2002 CLK430
Easy is a relative term, but a flex disc is very easy to change. Eight bolts hold it in place. With my car on ramps in the garage, either flex disc (front or rear) can be out in 10 minutes. Dealer price for parts is $125. $90 at Autohaus AZ.
Stiggs, drive down to SoCal. You can stop off at Autohaus on the way in. We'll swap out both flex discs, take some photos, and make a DIY web page. It'll be a smooth 3000 mile drive back home.
Old Mar 3, 2010 | 08:56 AM
s4avt's Avatar
'03 CLK 55
: ) Looking forward to see DIY Web
Old Mar 3, 2010 | 09:03 AM
Chappy's Avatar
AMG
LOL!! If Stiggs drives down there, so will I!!
Old Mar 3, 2010 | 05:34 PM
Stiggs's Avatar
2003 CLK55
I think Ill pass on the drive down! lol
Old Mar 12, 2010 | 10:02 AM
spykesta's Avatar
01 CLK55
I have this same problem exactly, 40 mph up to about 60 mph when first driving car, the vibration actually goes away after driving awhile, i.e. 30 minutes or so, I was originally thinking tires as well but now do not know what to think.
Old Mar 12, 2010 | 10:39 AM
s4avt's Avatar
'03 CLK 55
Yep!!! we are in the same boat.
It is worse when car is cold or not driven for a while. and it gets very weaker once it is warmed up.
I will try to get my engine and tranny mount replaced and than flex disc. so I can find out what the hell is wrong..
