little oil leaking from my head gasket. any DIY?
HG would be much more $$ and time.
Get the manual and take your time..... looks easy enough.
Someone from here (PTE or others) can chime in if there are any special MB only tools needed to do this.
my mechanic also stated that I would take a lot of time cleaning, what specifically will I be cleaning, and how will I be doing it? should I be using solvents?
If there is oil leaking from the smaller covers on the top, u can now remove the small torques screws and pry the covers off ( lots of prying needed, they r stuck on there real good!!) U also need to buy the black benz slicone because there is no gasket under the small covers.
clean covers and head, new gasket and reinstall.
i followed you up to the point of prying the covers off. what should i use to pry them? what do you mean i need the black benz silicone? where do i buy it from? the dealer? do you have a part number? how do i apply it? also, how do i clean the covers and head? with a towel? with any type of solvent?
sorry for the questions, i want to do everything right the first time.
do i need to torque the screws back when i put the cover on?
btw, from the looks of the instructions, i'd have to remove the fuel line. any precautions with this? I wouldn't want fuel leaking everywhere.
Just ask for the black sealer at the dealership, they know what it is, its a small tube. You only use it on the small cover only!! u fill the groove on the cover and set it in place then u put the small screws back and let it dry. You then put the new gasket in place and bolt it back on. Just dont tighten them too tight.
Only the coils need to be removed. A tip.... get the cover ready for install then clean the head , bacause oil will slowly drip on the gasket surface.
So Have all the parts clean & ready too assemble. I did a bench assy , Got some extra nuts & washers and put together the little .covers / baffle assys with the sealant . Let it dry for an hour. Then scotch bright pad the out side surface . Then spray painted them GSA gray. . I had tryed other brands of sealant , but the covers would start to leak again after a hard run. So Stick with the OEM sealer. Cheers _PTEngineering
How much HP can be had from k cams? The do it yourself looks very easy..... compared to a small block ford which requires pulling the entire front of the engine off.
