Deleting converters 208
I see, I guess I just didn't see the o2 sensors behind the first bank. Do any1 offer o2 simulators for this application? Hmm I wonder if an o2 simulator could be spliced into a mb pigtail? Just thinking out loud but I would imagine an obdii o2 sensor would function the same for a german car as an American car hence an o2 simulator would function the same. I may need to dig into this a little.
Not trying to lecture. Everyone has their own standards. Just hate to see someone go to a lot of trouble to remove the front converters and reprogam the ECU, just to find out you no longer like driving it.
The O2 sensor color codes are here.
works, it's a fast and simple procedure. As
far as the eye watering stuff, well the exhaust comes out the back so that's the other guys problem. But to counter the mb in it's purest form; the German spec doesn't have cats as I understand so coming closer to that would make it more of a thoroughbred not less.
The modern fuel injection will not be as bad..... you can remove cats from a modern fuel injection engine (assuming stock cam), and not get this situation.
All bets are off with offroad exhaust (no cats) + modern fuel injection AND aftermarket cam(s)....... then you're back into the smelly exhaust in some cases.
My 1cents worth
- All german vehicles have had CAT's for at least 20 years that I know of. My work in emissions compliance for EU was limited, and the standards for deisel are less strict, but unless I'm missing something, all MB's have had CAT's for quite some time, as EU emissions standards for gasoline engines have basically piggy backed US standards for quite some time
- betrezra is correct that tune will have a GREAT deal to do with it, but most will still notice the difference in their own cars, even if you don't care about everyone else. It just depends on how sensitive you are, but unless you have a wife/girlfriend that loves classic cars, SHE will notice. If it's a cabriolet, the difference will be even more pronouced.
- MarcusF is also correct: unless MB was getting cheap on the CAT's on an $80k vehicle, or unless you're shooting for 700hp, I'd be surprised if you gained anything but noise. I'm not sure how much clearance there is on the front cats but a good set of high flow cats would definately flow enough for this vehicle, and you'd still be able to sell the car in other states with emissions test.
- Yes, I'm sure you can get by with 02 simulators, but personally, I'd never pull the close-coupled CAT's off a vehicle without doing a retune. There's a lot of interdependance going on there. It's a system. But I'm weird that way. I recal after every mod. Probably the main reason I won't be moding my CLK much: no one seems to make aftermarket tuning software for it like they do for virtually every US vehicle.
-my g/f has her own car. The CLK 55 AMG doesn't strike me as a chic friendly car(there are many exceptions I'm sure) as denoted by the ride quality or lack there of.
- I like noise, iirc there have been dynoed gains of 19hp by removing the rear cats and the resonator with no tuning. I do however see a benefit to it but not on the exhaust. Other than o2 content the ecu doesn't care what you do to the exhaust. Fitment will not be a problem bc I will just be relieving the cats of their guts. As with most peeps that decide to modify their cars, I plan on keeping it.
- doing a recal with every mod would be ideal but there are situations where it isn't necessary. There are quite a few members on here with heavily modded CLKs that seem to be doing just fine. I personally don't plan on going that far but you never know. Also just bc a car is not what you are used doesn't mean it's off limits. That kind of close minded thinking is just a way to stiffle innovation and if everyone thought like that we'd still have horse drawn carrages.
- I'm not trying to change anyones mind but I do see the need to engage against sleights both blatant and veiled. All in all you do or not do to your car what makes you happy. The descision is up to the owner; if the owners descision causes concern with others by all means voice those concerns. But at the end of the day the descision still lies with the owner to either reap the consequences or the benefits of.
Please post back your results from the device you listed. It doesn't appear that any exhaust would flow "through it". "Up to it", yes, but not "through". If so, it'll be interesting to hear the results.
