Remove/replace intake manifold
Old Oct 1, 2010 | 09:23 AM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
Just posted this in the non amg forum too:
I am attempting to replace my intake manifold with a ported and polished mani this weekend.
Has anyone removed their manifold? Any tips/tricks or special tools/materials I need?
DIY link? I fid my WIS to be less than user friendly. Thanks!!
Old Oct 1, 2010 | 05:24 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Haven't removed mine but doesn't look bad. Id follow the usual back and forth bolt removal involving aluminum parts for starters though. You'll definitely want the torque spec for the reinstall and Id use a dab of anti-seize. Looks like the valley pan stays in place so you wont have to deal with that oily mess.
Old Oct 2, 2010 | 01:41 AM
samvel1981's Avatar
W124 E320, w210 E420,W210 E55 AMG,W220 S430 (sold),W163 ML 55AMG
hello
you will need 10mm ,8mm,sockets this is mane tool that you need
i deed take mine of their is nothing to worry the only thing you need to do is cut some wires i believe it is a/c cluthch wire so just cut that wire than reconnect nothing special or you can spend about 1-3 hours unbolting some parts to take them out
so
first you need to do is take that metal pipe of in the back of manifold (two 8mm bolts on one end and the other end is a big nut )(twist that pipe and pool it out)
than take that air motor in the front (one 8mm bolt)
than unplug all weiring and take all the clamps of your injectors
unbolt fuel rail 4 bolts move it to the side with weiring
than unbolt your intake manifold i think 10 bolts and it will be out
so it is not that hard when you start doing you will figure it out have fun
i may take some pics tomorrow for you
Old Oct 2, 2010 | 06:23 PM
Hey Sam, thanks a ton for the info!
Old Oct 3, 2010 | 01:16 PM
samvel1981's Avatar
no problem
good lack to you with your project
Old Mar 17, 2016 | 01:01 AM
sirswift93's Avatar
CLK320 Cabrio 2001
Hi Bobby,
What do you mean by "the usual back and forth bolt removal?" How should I handle the removal of the old bolts and the install of the new bolts?
Old Mar 17, 2016 | 01:07 AM
sirswift93's Avatar
CLK320 Cabrio 2001
I will be installing my new intake manifold this weekend.
Originally Posted by samvel1981
hello
so
Hi Samuel,
I am actually going to tackle this in a few days with my 2001 CLK 320 Cabriolet. Is there any real difference between the w209 and my w208?
I read the WIS and it says to release the pressure off the fuel rail with a special MB tool; is there another way without buying the tool. Is it necessary? I did purchase the alloy pegs from my local dealer for lining up the new Intake manifold and the gaskets. It was worth the $50.
DaGuitarist, Did you ever end up doing it yourself? Any tips?
All the best guys.
Swift
Old Mar 18, 2016 | 02:57 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
The internal baffles on the M113 intake are controlled by a vacuum hose that is connected to the front of the intake. The ported and polished unit you are installing must have that same intake hose installed, you can only install it by taking the two halves of the intake apart. Without the hose you will have a vacuum leak and the low speed/high speed baffles will not work (giving you less power than you hae now without porting).
Old Mar 19, 2016 | 11:10 AM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
Bro Florida writer,
I think he is a L6 or V6 posting in a thread from 2010.
