my s/c "kit" is coming couple q's
Old Jan 17, 2011 | 07:56 PM
dohcfiend's Avatar
2001 CLK 55 AMG.......... 2001 Corvette Z06.........
Donor car: 2005 e55 amg
receipient: 2001 clk 55 amg
whats coming:
s/c assy, heads, cams, airboxes, water pump etc.....
im in negotiation with the seller and if the price is right I may get the rods/pistons too.
Good idea or just try to make it work with extra compression by reducing boost and/or timing?
donor CR 9.0:1
receipient CR 10.5:1
Next, is the stock rad sufficient to cool the s/c setup?
Old Jan 17, 2011 | 07:59 PM
dohcfiend's Avatar
my thinking is if i swap in the rods/pistons my m113 basically becomes an e55 amg engine which tuners will be much more familiar with vs a hybrid with the headache of extra compression. i also believe more power can be had by using the lower compression pistons bc i can up the boost more.
opinions?
Old Jan 17, 2011 | 08:01 PM
dohcfiend's Avatar
lastly, are there any clearence issues i should be aware of when changing over the serpentine system? mainly engine to radiator interference?
Old Jan 17, 2011 | 09:01 PM
dohcfiend's Avatar
eh ive thought about it and as long as i can get a deal on the pistons/rods im gonna get em bc ill be able to run more boost than anyone with a "kit"
Old Jan 17, 2011 | 09:13 PM
betrezra's Avatar
C63 507 AMG DA Car #19
While my experience with "Other" brand cars would say the lower c/r pistons would be a benefit for your blown app, i've heard from a couple threads that serious built kleemann cars attempted reduceing c/r and lost power. I think it had to do with the blower NOT being able to be spun up enough to make the boost to make-up for the lost c/r. (don't quote me, it's what I recall).
Since you're not using the kleemann... this should not apply to you.
Are you getting the e55K ecu as well?
Wish I could help more with the cooling question, and ecu issues. I'm clearly a MB newb..... and am currently relegated to being a credit card tuner
Old Jan 17, 2011 | 09:44 PM
dohcfiend's Avatar
i tell ya its difficult bc the tech info just isn't here and it should be for an engine that is this old.
Old Jan 17, 2011 | 09:45 PM
dohcfiend's Avatar
appreciate the info tho ill take every scrap i can get. since the heads were off can your builder answer a question for me?
are the pistons forged or hypereutectic?
Old Jan 18, 2011 | 05:52 AM
betrezra's Avatar
I'm pretty sure my N/A heads are HE.
Don't know about the 55K heads.
Marcus is the tech man around here. Maybe he'll chime in.
Regarding tech - I totally agree about the lack of detailed tech/info. I wonder if there is a good MB ECU tech book avail>
Good to see a hotrodder running around here.
Old Jan 18, 2011 | 08:31 AM
blackbenzz's Avatar
haters crazy
Forged crank and rods ... hypereutectic pistons
Old Jan 18, 2011 | 09:02 AM
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
Just swap the engines? Will make it a little easier, at least you wont need to rip into the bottom end. Buy the e55 setup, Sell your N/A engine and use whats left to get that bad boy running! Good Luck!
Old Jan 23, 2011 | 07:06 PM
dohcfiend's Avatar
i thought about buying the engine but someone on here swapped an e55 engine into clk 55 and there were alot of wiring issues from what i read. besides ive already bought all this stuff.
Old Jan 23, 2011 | 08:28 PM
MarcusF's Avatar
2002 CLK430
In addition to the parts DOHC has purchased, 55K engines have different part numbers for the crank and block. In addition to the rods being a different, the rod bearings are different as well (part numbers). It will be enlightening to find out whether K rods will fit on a non-K crank. The 55K has double springs, so the 1550530020 springs may prove beneficial.
Old Jan 23, 2011 | 09:55 PM
dohcfiend's Avatar
i haven't purchased the rods and pistons yet. i have an appointment with the dealer next week. ill get em to pull a set of rod bearings to see if there is any difference in size. I should be ok on the springs bc i bought the complete cylinder head assemblies already.
thanx for the info.....def worth investigating.
it will be my assumption that they will interchange without issue if merc is like any other manufacturer.
Old Jan 28, 2011 | 09:47 AM
ahmed18881's Avatar
frankenstein 2001 CLK 430
the mechanics part is very easy in this conversion, but you will defenitly need to change your ecu and engine wiring harness to make it run on the e55 software, also the amout of boost you will be running is going to be too much. i have done the same thing to my clk but i did custom tune my ecu and fabbed a custom intake because i retained the air mass, this conversion is not for the faint heart and i really suggest you not pay by the hour for it. you will also need the timing case + all the pulleys to run the double pulley setup. if i was to do it all over again i wuld have bought a compete engine, ecu, and harness. that way you will retain the oem quality + u can upgrade more...
Old Feb 2, 2011 | 06:25 PM
dohcfiend's Avatar
i went to the dealer and unfortunately they didn't have any parts in stock for me to compare but they did inform me that the rods are physically the same but the bearing thickness may be different. with that in mind looks like all i may need to make it work would be to use clk 55 bearings on e55 rods. im not sure of the timing case, can you describe it? i know i have all the pulleys n crap tho. luckily the person that has the parts hasnt shipped them yet.
Old Feb 2, 2011 | 06:29 PM
dohcfiend's Avatar
honestly, it will take some time before this becomes a reality. basically i have a stick intake and a set of 05 e55 heads coming. i will send those to a machine shop and swap them then drive the car until something breaks before proceeding with the swap bc it appears it will be easier to pull the engine to make it happen.
Old Feb 2, 2011 | 06:37 PM
dohcfiend's Avatar
found out the pistons are gone
Old Feb 2, 2011 | 06:38 PM
dohcfiend's Avatar
hmm i may end up selling the s/c kit minus the cyl heads and going with a full engine swap later.
Old Feb 2, 2011 | 09:11 PM
MBfinatic's Avatar
e36 318i, 2004 sti
if u sell it let me know about the kompressor
Old Feb 4, 2011 | 11:37 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I agree, swap out the engine in its entirety.
I have 2 IHI AMG superchargers for sale.
Old Feb 4, 2011 | 12:16 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
This swap has already been done by 4 people . One guy in the W203 C55 section with success(supercharger and accesories only), MBenzman with the W208CLK55(supercharger and accessories only),MoneyOne who swapped out his 5.4L out of his C43 and dropped in an entire 55k motor,and,a guy with a CLS500 who recently swapped out the whole entire engine and put in a 55k motor with much success.
Old Feb 4, 2011 | 12:45 PM
betrezra's Avatar
Motorwerks in Houston did it also to a C320.
Old Mar 14, 2011 | 05:12 PM
ahmed18881's Avatar
and a guy wit a clk 430 with a 500 engine and a e55k kompressor
Old Mar 14, 2011 | 05:38 PM
dohcfiend's Avatar
i stand to lose some cash here since i didn't get the timing case or whatever. found out too late i need that piece to make the swap work .
i will recoup what i can and move on. i'll definately make use of the heads and possibly use the cams as cores to have ground for more duration.
dohcfiend's Avatar
unless i can score a timing cover/case cheap this swap is doa.
