w209 320 Crazy Electronics, HELP!
Old Mar 18, 2011 | 09:50 PM
EdZorX's Avatar
2004 Mercedes-Benz CLK320; 2000 BMW 540i
Exclamation w209 320 Crazy Electronics, HELP!
So when I got home yesterday my car tried to turn on the lights, I got the HIDs (it was dusk but not dark enough) it showed me with "low beam right" warning message... so I thought oh great, bulb's out... if it only was just the bulb
I parked it in the driveway to look at them and yes the right was out, so when I got back in the car the tranny wouldnt let me switch into drive! So i turned it off and the lights, started it up and then it did shift into drive so I could park it.
I drove all of today with the lights off and the car had no problems, and then comes the night driving when I was coming home, I started the car and tried to turn on the lights... no all hell broke loose, 6 warning messages were bombarded my way!
- Low Beam Right
- Low Beam Left
- ABS Malfunction
- BAS Malfunction
- ESP Malfunction
- Check Engine
Now also the Check engine light is on and the weirdest part also is that when this happened I noticed it was the trigger for the transmission not to shift out of park. I had to turn off the car, with the lights off start it up again, this time I could shift into drive (if i tried to turn on the lights after the tranny would ONLY be in second, no upshifts or downshifts)...
And all of this cause of 1 HID bulb??
Please help if you have had or have heard of anything related to this!
Thank you
Old Mar 21, 2011 | 04:20 PM
MTLdude's Avatar
2005 CLK 55 AMG
Looks like a voltage drop or the voltage cannot stay high enough. This can be caused by a weak battery or a bad alternator. When was the last time you changed your battery?
Old Mar 21, 2011 | 05:21 PM
EdZorX's Avatar
I was freaking out about it but it ended up being not a burnt bulb like I imagined, but a completely shattered one... i dunno how it happened but the bulb was in pieces, I even had to fashion a small tube to connect to the vacuum so i could get the pieces out, and the good news is the bulb from my BMW was the exact same philips that Benz uses so now its all perfect 0 codes
Old Mar 21, 2011 | 10:19 PM
Moedy's Avatar
'05 CLK55, '04 CLK320
glad to hear it all worked out for you and next time post in the correct forum you little newbie you
Old Mar 22, 2011 | 12:12 AM
EdZorX's Avatar
haha thanks, i'll keep that in mind, where was this newbie supposed to post?
Old Mar 22, 2011 | 12:13 AM
EdZorX's Avatar
oh wait duh, i was not discussin the clk55 amg and clk63 amg, sorry! :p
Old Mar 23, 2011 | 08:16 AM
Stiggs's Avatar
2003 CLK55
Posting here was fine since some mebers with a W209 might have had the same problem. Who made you the forum police?
Old Mar 23, 2011 | 06:52 PM
Moedy's Avatar
Posting in the correct clk forum would get him more responses. I wasnt being rude to him. I am the forum police, let that be a warning to you
