CPS location for 2002 W208 CLK55
Old Mar 22, 2011 | 10:31 PM
pnsji's Avatar
2 55s
I have been trying to locate this piece without any luck. Have anyone ever replace CPS for the 55?
I found the reference to: http://www.benzworld.org/forums/w210...-pictures.html
Old Mar 23, 2011 | 03:37 AM
pnsji's Avatar
2 55s
After a while, I found it!
The CPS is much further back then the area I was looking at. It is between the engine and the firewall, mounted pointing downwards.
Basically I was following this wire which is the only naked wire without wire jacket and the smallest one (marked in red)
Using right hand and standing on the driver side, I was able to feel the lever to unhook the harness. For illustration purpose, I am using the brand new sensor, attach to the wire.
The lever (marked in yellow) is towards the center of the car. you need to push the lever and then pull it to unhook.
And here is the position of the sensor (marked in blue) and the wire (marked in red). Please note the location in relation to exhaust down pipe.
Next is to actually replace the sensor. I need the size 8 torx socket now
Old Mar 23, 2011 | 06:21 PM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Mine is on order as well. It finally happened to me too. I will be replacing it this weekend.
Old Mar 24, 2011 | 12:26 AM
pnsji's Avatar
2 55s
Let us know how it goes. If you see the last picture that I posted, there is a black wall covering the sensor. I am guessing the wall function is to protect the sensor against the heat from the exhaust pipe.
I can't get enough clearance within the walled area. I tried to remove the wall, which is mounted to the the transmission case (you need to use Torx E14 socket) and it was tight space and tight bolt. So removing the wall was not working for me.
At this point, I am ordering a tall E8 socket with 1/4 in drive.
Old Mar 24, 2011 | 05:08 PM
unlukky's Avatar
T14? For some reason I thought it was T8. Anyway, yes thats a heat shield. I plan on using a torx socket on a 1/4 inch wobbly.
I've done this before on a friends E430, but not my CLK55. Good luck.
Old Mar 24, 2011 | 05:12 PM
ohlord's Avatar
There
is another good write up on www.peachparts.com resource section diy articles.
Easy diy on M112 and M113 engines.
Old Mar 24, 2011 | 07:30 PM
pnsji's Avatar
2 55s
E14 is for the transmission torx bolt which holds the black wall.
E8 is for the CPS bolt.
I am waiting for E14 1/4" to arrive (both regular and deep sockets).
Old Mar 29, 2011 | 12:13 AM
pnsji's Avatar
2 55s
I got the E-8 1/4" drive and I was able to replace the CPS.
Old Mar 31, 2011 | 12:36 AM
unlukky's Avatar
Me too. I just used a 12 point 1/4 inch socket. In and out.
