ESP and brake bleeding
Old May 7, 2011 | 12:20 AM
lsboogy's Avatar
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
My daughter is out of the hospital, and she wanted friends over for watching movies tonight (it's been a couple of weeks since I've had a house full of kids), and I thought I would go out and bleed brakes on some cars (springtime - I do it every year) while they had their fun. I did my E320, and the old 230C, and then was about to do my 2002 CLK55 and my neighbor told me I needed a star diagnostic system to run the esp and abs systems on the car while bleeding it. Is this correct? Do you have to go to a dealer or indy shop to bleed the brakes on these cars?
I use a power bleeder system on my other cars, and they are just pour in fluid, pump up pressure, and open bleed valves until fluid is changed (I run ATE blue/gold for a visual). I also got ATE SL.6 (low viscosity DOT4 stuff) for this car. Can I just rig up the power bleeder and run like my other MB's?
Old May 7, 2011 | 02:33 AM
MarcusF's Avatar
2002 CLK430
I've bled my brakes at least 4 times, but I can't get the Motive Power Bleeder to work. At 2 BAR the fluid barely dribbles when I open a nipple. Instead I use a 1-man-bleeder contraption. It's basically a pump the pedal method - no STAR box used.
Old May 8, 2011 | 12:25 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
How often should you bleed the brakes? Every 2 years regardless of mileage?
Old May 8, 2011 | 09:28 PM
MarcusF's Avatar
2002 CLK430
Yeah, it's every two years. Brake fluid is hygroscopic - absorbs water from air. Once enough moisture is absorbed, brake parts start corroding. It used to be common for Corvettes to need calipers after a few years. Old fluid was considered the cause.
Old May 10, 2011 | 12:11 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Good thing I read your post. I was going to order the Motive this weekend and try to bleed the brakes. Do you remember the brand/model of the 1-man-bleeder tool you used?
Could you confirm I can use ATE Blue and ATE 200 (DOT4) on my 2004 CLK500?
Old May 10, 2011 | 01:31 AM
MarcusF's Avatar
2002 CLK430
I have a bleed-o-matic, which I never use. I’ve used old soda cans, but it works better/keeps the garage floor clean if you can see how much fluid is in the catch can. When I can’t find my patented water bottle (which seems to go missing between 2-year fluid flushes), I use the 5 ounce reservoir bottle that came with my Mityvac and a section of hose. The "patented water bottle" is a hose in a 12 ounce clear water bottle - drill two holes in the cap and run the tube through one. Set the water bottle in an old coffee cup and it won’t tip over.
I’ve been alternating between ATE blue and 200 since I bought this car. It will work fine in yours.
Old May 10, 2011 | 03:11 AM
DRBC43AMG's Avatar
I have always used a glass coke bottle with some plastic tubing to attach to the brake caliper nipple, and I get a second person (usually the wife) to do the pumping of the pedal. I use a syringe to remove some of the old fluid in the brake reservoir and replace with some new clean stuff. Gets through the pipes quicker.
Old May 15, 2011 | 12:24 AM
dsgn's Avatar
E Class
How much is the motive bleeder and what's the turn-around time to perform the labour? Any special attachment(s) or fittings needed?
Old May 15, 2011 | 01:06 AM
MarcusF's Avatar
2002 CLK430
A Motive power bleeder is between $50 and $70, depending on the supplier. If the car is on a rack, it takes about 30 minutes. At home in a garage is longer. No special tools are needed.
Old May 16, 2011 | 02:19 AM
dsgn's Avatar
E Class
Thanks!
Old May 17, 2011 | 12:34 AM
Moedy's Avatar
'05 CLK55, '04 CLK320
good post, marcus can you recommend a power steering fluid as well? I bought the magical mercedes coolant from the dealer so I want to see what else I need for next time
Old May 17, 2011 | 01:06 AM
MarcusF's Avatar
2002 CLK430
I've never swapped PS fluid. What year did MB begin using synthetic PS fluid?
Old May 17, 2011 | 03:15 AM
Moedy's Avatar
so youre saying I never need to replace the power steering fluid for the life of the car?
Old May 17, 2011 | 04:48 PM
MarcusF's Avatar
2002 CLK430
I'm going to guess my post was a lot less clear than I intended. Allow me to rephrase the answer. Yes, I can recommend a PS fluid. Although not having "changed" the PS fluid in my car, my recommendation would not be on based on experience. You may wish to ask someone with experience in the area of using a PS fluid purchased somewhere other than a dealer.
As long as we're hijacking a thread, does anyone know what year Mercedes-Benz began using synthetic PS fluid? This question is not to imply synthetic fluids need not be changed. The point if this question is to know when Mercedes-Benz began using synthetic PS fluid.
Old May 17, 2011 | 10:16 PM
lsboogy's Avatar
synthetics
I think a word (maybe a thread, maybe a forum) could be lent to synthetics. Big thing to remember with synthetics is the base grade - most of what you see out there is grade 3 (or III) base stock, and some is grade 4 (IV). Grade 5's and exotics are for those with the money (military and aerospace), and are usually used as additives.
Difference is in how they are made - Grade III is really just highly refined dino oil - most of the sulphur and ash are removed by cracking and other methods, but they still have sulphur (really bad for your metals) and ash (grinding stuff) in them. Grade iV is chemically engineered, and has almost no sulphur or ash, and is a better lube for all things.
I build gyro's for aerospace applications, and have been specifying oil and grease for these applications for many years. A synthetic will allow you to change oil less often, but they still need to be changed. And power steering fluid is simply oil (low viscosity/low compressibility type) with some additives, so you should change it - I do mine every couple of years. I get it at the dealer for my MB's - now run synthetic in them, and run Redline in my other cars. I think my 95 came with dino oil in the PS box.
Old May 18, 2011 | 02:39 AM
DRBC43AMG's Avatar
Interesting post.... Thanks
Old May 18, 2011 | 10:11 AM
2MCHCAR's Avatar
I have another brake maintenance question; I created a new thread so
I could stop the thread jack (sorry OP). I would appreciate your expertise Marcus!
https://mbworld.org/forums/clk-class...-question.html
Old May 19, 2011 | 03:20 AM
Moedy's Avatar
yeah sorry I misunderstood what you said and from your past posts I was thinking you used to work at a dealer so thats why I thought to ask you
thank you
Old May 20, 2011 | 11:38 AM
MarcusF's Avatar
2002 CLK430
Nope, I’ve never been employed by a MB dealer. Decades ago while in college I was a P-car wrench/apprentice, have rebuilt/repaired countless air cooled P-car motors and do almost all my MB maintenance (and some for friends), but haven’t been employed in that area for decades. Rather than changing/swapping brands, have you considered ordering a quart from Autohaus AZ? I don't think the system holds more than about a quart. They have MB fluid and their rates must be lower than the dealers. Although you'll still have to know whether your car uses synthetic or not.
Old May 20, 2011 | 06:29 PM
Moedy's Avatar
I dont mind paying a few more $$ for something like fluid as long as its in stock at the dealer. Its the stuff thats not in stock and ridiculously over priced that I'd rather go online to order. Like valve cover gaskets, they wanted $40 each
