Performance figures for Technik CLK55 intake manifold
Old Feb 19, 2002 | 11:33 PM
Samir's Avatar
2017 C63 | 2018 E63
[all figures are RWHP...crank figures are adjusted 20%]
After the install today, the car had a best run of 297.1HP(371.3HP) and 309.8ft.-lbs(387.3ft.-lbs) to the wheels, compared to my best base run a few weeks ago of 282.6HP(353.3HP) and 301.8ft.-lbs(377.3ft.-lbs) of torque. So fore/aft results are a net gain of 14.5HP(18.1HP) and 8ft.-lbs(10ft.-lbs). Please keep in mind that my car does not have catalytic converters and therefore is not producing as much overall power as a stock CLK55. A CLK55 with catalytic converters will see even bigger gains. Watching the CLK55's computer adjust the air/fuel ratio was a thing of beauty. The first run, the car put down a dismal 255.7HP, but with each ensuing run, the computer kept tuning the proper air/fuel ratio to accomodate the increased airflow of the intake manifold and eventually topped out at 297.1HP...German engineering is unparallel. Nice to see there is A LOT of HP left in this engine...will have more figures after the cam/head package. Also for a few runs, the governor happened to be in a "good mood" and unleashed the CLK...happy to report it almost hit 200MPH on the dyno (198 to be exact). This car is absolutely amazing
Old Feb 19, 2002 | 11:59 PM
Amir's Avatar
E39 m5
Where can I sign up ?
Damn Samir, nice work man......!!
Old Feb 20, 2002 | 12:25 AM
Garee's Avatar
Hm.... how come no cat would net you more power than with a cat?
I thought taking out the cat would improve exhaust flow? If running without a cat decreased your power, why'd you take it out?
Just curious.
Old Feb 20, 2002 | 12:51 AM
Samir's Avatar
2017 C63 | 2018 E63
Just curious.
I removed the cat because I wasn't happy with the exhaust note. The AMG cats are extremely high-flowing and help create just the right amount of backpressure for the naturally aspirated 5.5L V8. Hence, I've seen other CLK55 performance figures with cats, who have put down more power to the rear wheels.
Old Feb 20, 2002 | 02:42 AM
Garee's Avatar
Oh, I see...
But no cat in California? Isn't it a big NO NO?
Old Feb 20, 2002 | 03:09 AM
Amir's Avatar
E39 m5
clk 55s have 4 cats I believe....
Old Feb 20, 2002 | 10:44 AM
Samir's Avatar
2017 C63 | 2018 E63
Yes...you are correct. 2 pre-cats and 2 main cats. I still have both pre cats.
Old Feb 20, 2002 | 10:50 AM
Brian Yee's Avatar
'01 CLK 55
Nice gains from the intake system! How much does the unit cost, how long /involved is the installation, and where do I find one??
Thanks.
Old Feb 20, 2002 | 12:23 PM
Mr. Vanos's Avatar
MBWorld Founder
2020 GT R Pro, 2019 GT3 RS, 2018 GT3 Touring
Samir, out of curiosity, who's manifold are you using? Pics of the install?
Old Feb 20, 2002 | 03:57 PM
bodyart27's Avatar
CLK55
very cool!
way to go!
My best runs at the wheels where: Max Power 294.5 @ 5900
Torque 314.0 @4500 using the K&N drop ins & stock rims / tires. You're running 18s? right? That will pull your numbers down some I believe.
So hard to tell different dynos / wheel combos - but a pick up is a pick up !!!
PLEASE post pics and pricing. Does the setup use stock filters or is it a CAI (Cold Air Intake) setup.
~shell
13.7 @ 107
Old Feb 20, 2002 | 10:24 PM
Samir's Avatar
2017 C63 | 2018 E63
The intake manifold is of our own creation. We port/polish the intake runners, enlarge the intake plenum and modify the internal runners to help increase aiflow velocity and create a "ram air" effect. Cost is $1499 for a complete unit without core exchange or $599 w/ core exchange...$300 for installation (4 hours....core exchange takes 1 day for modifications). We are located in Beverly Hills.
Old Feb 20, 2002 | 10:34 PM
Samir's Avatar
2017 C63 | 2018 E63
Re: very cool!
~shell
13.7 @ 107
Your engine appears to be particularly strong...making about 392ft.-lbs to the crank (hehe...you're one of the lucky ones ). I'm running 19s, so that might shave off a few ponies (the 1inch radial increase in rotational mass vs. 17s is significant, but nothing dramatic). I'm interested to know if I were to install the cats again, whether I would pick up some serious power (seeing that you are still making more torque than me with only intake). Either way, I was interested to see the overall gain from my base run with the new manifold, and am pleased with the results. However, the M113 is still making more torque than HP, leaving me to believe a cam/head upgrade will do wonders for this engine.
Old Feb 21, 2002 | 12:08 PM
jrtw's Avatar
2002 Capri Blue CLK Cab
Thumbs up I have to have one...
Samir,
Would this unit work on my 02 430? I thought If this can be done for my car please let me know. You can email me at blueclk@aol.com or post it here, the info might be helpfull for others.
1.) How long does it take to complete the process?
2) Do you provide any type of warranty?
3) Could I drive down and have it down since I am in Michigan?
dan
Old Feb 21, 2002 | 06:13 PM
Samir's Avatar
2017 C63 | 2018 E63
Re: I have to have one...
Originally posted by jrtw
Samir,
dan
Yes...all Mercedes M113 V8s (430,500,55) are compatible with this modification.
In answer...
>The actual removal/installation takes ~ 4 hours. If we modify the existing unit, then we require one day for machining.
>Yes, we provide a 2 year 24,000 mile warranty on the manifold if we install it, or a 1 year 12,000 mile warranty if installed by a different technician/shop. If installed properly, this manifold will never fail.
>Most certainly, however, to save you the trip, you could either purchase a new manifold or send us your stock manifold...then have it installed by a Mercedes technician locally.
Feel free to email me if you have more questions => samir@technikonline.com
