HPS GEN 1 Pulley
EDIt:
I think ive read and found every post he made here and there and nada
https://mbworld.org/forums/2435485-post16.html
https://mbworld.org/forums/1700475-post12.html
https://mbworld.org/forums/1712216-post27.html
http://www.benzworld.org/forums/w210...ml#post1996457
You may be able to get more boost out of the Gen1 then E55cent did but I'm guessing you will be pioneering the way as not many other 55 owners have ventured there.
BTW I saw in another thread where you mentioned getting a hell of a price on your Gen1. I'm curious as to what you paid.
i will look through that thank youEDIt:
Yep missed all of those lol! Looks ike he was running 2.25 I might go for 2.00 and see what happens worst case i overwork and destroy the little blower in which case i can upgrade to a larger one, as I will allready have 99% of the componets to be properly supercharged!
maybe ill get a 2" made and a 1.75" and go from there...HPS supposely runs rich anyways so adding boost will lean out there factory tune wont know until i get it on a wideband I will post up with pics when its done....
2.0 for pulley size as said above 5.5-6psi (supposedly tested)
the crank pulley is 151mm right? =to 5.95"
that calculates 9psi boost which is 33% off from supposed real world results
so 1.75" pulley would = 12.6psi minus 33% so roughly 4.2 = 8.4psi
Does this make sense? and the real question if it does will 1.75 spin to fast? that would make a ratio of 151mm/1.75=
Since- 151mm crank pulley, 1.75"=44.5mm 151/44.5=3.39
Ratio- 3.39
