Need Kleemann SC Intercooler Replacement
I would like to purchase a different intercooler now but I have no idea how to make an educated decision on intercoolers (I don't know any specs), since I have never purchased an intercooler separately.
I'm hoping one of my experienced Kleemann SC Brothers can give me some tips, advise, or Intercooler recommendations.
Cory advised the klee plate style he is very efficient. Perhaps more so than aftermarket versions.
I'm sure there is a good a/m solution out there with all the roots/whipple/twinscrew/eaton blown v8's out there..... cobra, shelby, covette, etc.......
Are you running water/antifreeze? Water only can be corrosive.
Is blower cooling isolated from engine cooling system?
You might be able to have your klee h/e repaired by a competent rad repair shop? They might be able to det cause of failure.
GL.
Unfortunately for me, I need a 1" barbed hose fitting (Like Kleemann's H/E) and Eurocharged Unit has a welded 3/4" fitting.
GL.
https://mbworld.org/forums/c32-amg-c...nger-fits.html
I was running antifreeze and my Blower's cooling was blessed at Kleemann HQ by Reverend Cory.
I found that aftermarket E55/C32 H/E is exactly what we need for replacing the Kleemann Units. I'm going with FTP unit (see below) since I can change out the hose fitting barbs (they are not welded) to the 1" barb I need.
https://mbworld.org/forums/c32-amg-c...eat-click.html
I'm also going to pickup the FTP Oil Separator while I'm at it.
As always, I will document my install and report back my results! This will be valuable information for my Kleemann SC Brothers!
My catch can did not have real amt of oil after 10k miles...... Just about a 1/8" of residue. I'm back to stock now. Gl.
I might even re-dyno to see if there was anything gained.
Does anybody know how to bleed the Heat Exchanger System? Any DIY threads or how to's?
