W208 track car build
Old Apr 12, 2019 | 01:45 PM
  #151
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
WOW!!! looks awesome Quant! Where is the shop you're getting all this done? may just have them do the exact same thing to mine. Ended up getting a '19 S4 so the benz has fallen a bit to the wayside. But...I am still interested in getting my hands on the V2's so I will take those rear springs ASAP as mine have cracked lol. Hope as is well, congrats on the newborn! Did you end up doing dif mounts as well?
Old Sep 2, 2019 | 08:59 PM
  #152
Quant's Avatar
2002 CLK55
its been a while, as usual life and unexpected challenges slow things down. got interior setup with full carbon fiber from OCARBON. great quality, highly recommend to all. will post more pics in new thread with review etc...
Old Sep 4, 2019 | 10:03 AM
  #153
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Wow Quant so you have kW shocks and Swift springs?
Old Sep 4, 2019 | 10:54 AM
  #154
Quant's Avatar
2002 CLK55
yep, shoot me pm if you need more info on this. i'm going to penske soon. trying to figure out so many things! this time next year it should be all sorted
Old Oct 24, 2019 | 09:52 PM
  #155
Quant's Avatar
2002 CLK55
new toy and more info on w208 to come....
Old Oct 26, 2019 | 02:18 PM
  #156
MattCordell's Avatar
C43 AMG with a tune up
Nice car you got.
Do you have more interior photos of the carbon interior?
How much did it cost to re-wrap to carbon looks?
What are the gauges below the sterio?
Are they OEM from factory?
Short gear lever does it fit non tip-transmissions from 1997 to 1999?
Old Oct 30, 2019 | 03:04 PM
  #157
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
Great Stuff Quant.
i was away from the forums for awhile, but ive still been autocrossing mine and doing track days here and there.
Im gonna try and be more competitive in SCCA STX autocross class next year. we have a healthy class (5-7 cars per event) in the south bend region (not my local region of SCCA but its worth he drive for more competition).
Anyways, im always right there with the guy that has won the class points championship the past 3 years, he has a BR-Z/FR-S that he has build pretty well for STX class spec. I think i need to do the Quaife LSD install to get me over the hump and take the title from him next year. I beat him every so often but not enough, im usually 2nd in points end of season.
anyways, any pointers on the Quaife LSD install? ill be researching more over the winter and plan to try and have it done early springtime.
let me know if you ever lay down some times at Gingerman, Grattan, Mid Ohio, or Blackhawk farms road courses in the midwest, i have done track days at all of those in my CLK.
Old Nov 3, 2019 | 10:19 PM
  #158
Quant's Avatar
2002 CLK55
hi, i recommend you reach out to Birds UK about parts and install. there is some modification that needs to be done and they are the only ones that provide parts. i can look up details if you need it, but problem is that axles used to stay connected to the diff via a c-clip. moving to quaife makes it closed diff and hence need something else to keep axles from slipping out. it was actually a big headache to get it to work but not it seems to be holding up pretty well. other than this, the quaife unit has been awesome. i noticed difference right away! good luck in your racing! feel free to pm if you need more info. we can also compare notes on setting up car etc...
Old Nov 3, 2019 | 10:23 PM
  #159
Quant's Avatar
2002 CLK55
Originally Posted by MattCordell
Nice car you got.
sure will post up better quality pics on interior when i'm back home in a cpl of weeks. the trim is actually not a wrap but an actualy CF piece. OCARBON did work, and they are the best at it. they strip away the wood trim and lay CF sheets to replace it. result is honestly as good as most oem pieces i have seen!
the shifter is from clk BS, to install it you have to modify the shaft. there are cpl ways to do it but not that difficult.
gauges are not oem, i dont remember brand but they are generally very similar in size. i needed custom panel to make it fit right, but that not difficult either.
Old Nov 6, 2019 | 02:08 PM
  #160
Dziner82's Avatar
Sent you a DM on here to discuss more.
but im wondering for the sake of this thread - what about the wavetrac option? assuming the same issue would exist there.
hope you talk to you about it more offline - i get really scared by things that 'may not be as reliable as OEM', but this would still be reverse compatible if we wanted to go back to OEM diff? or its really hard to go back again?
Old Nov 7, 2019 | 05:43 PM
  #161
Quant's Avatar
2002 CLK55
not sure if they made wavetrac for our car. honestly my advice is to go blackbenz route and put w209 diff housing and custom axles. you will have more options for lsd and gearing. i'm very happy with my lsd but i did take me a couple of tries to get it right. best bet is contact birds UK, they are very helpful and knowledgeable
Old Feb 1, 2020 | 12:51 PM
  #162
Quant's Avatar
2002 CLK55
p&p heads from c55, with valve job and bronze guides. going with double valve springs to increase redline to 7k. also got set of arp head studs, not really needed for me but plan to rebuild engine at some point with lighter and higher compression pistons. figured why not get them now. i plan to dyno car next month, hope to share results with you guys then. ahh also got TB ported to 77mm, hopefully these open up engine up top.
Old Feb 1, 2020 | 08:07 PM
  #163
PapaChop83's Avatar
2004 CLK 55 AMG, 2012 Mazda 5
Those are beautiful.
Old Feb 2, 2020 | 12:05 AM
  #164
quik55's Avatar
Thank you for posting. They look beautiful. This is something along with larger cams that I hope to do in the future. With how cheap these engines are why not pick one up and just fully build it out?
Old Feb 23, 2020 | 08:17 PM
  #165
Chappy's Avatar
AMG
Sooo much WIN on this thread! 👍
Old Feb 25, 2020 | 09:49 PM
  #166
Quant's Avatar
2002 CLK55
thanks! i just picked up clean set of slk55 higher compression pistons to do my rebuild. so going after a full rebuild after all... not that the car needs it i have to admit
was going to go higher than 11:1 CR but weistec doesn't recommend it for the m113 engine so decided to go with this. my calc is that i will only pick up 6-10hp from this, so not major improvement.
Old Apr 8, 2020 | 02:16 AM
  #167
jikjakz's Avatar
w208 55 6 spd, w210 e55 6 spd, e36 s50 turbo
Love this build, been lurking since way back when. This thing is going to sound amazing revving to 7k! Also love it since there are not many people who see the potential in these cars. I think I fantasize about w208 clk dtm cars almost every other day. Planning on getting a clk55 myself soon and swapping in a manual trans in just like my E55 in the hopes to build a semi track car-ish.
Looking forward to your updates!
Old Jul 3, 2020 | 05:32 PM
  #168
Chappy's Avatar
AMG
Quant, are you still running Motul? Which kind?
Old Jul 3, 2020 | 05:55 PM
  #169
eurochargedw210's Avatar
w210 E55
You should check out Catcams!
Old Jul 3, 2020 | 05:58 PM
  #170
w210 E55
Did you get them Flowed before and after?
Old Jul 20, 2020 | 03:24 PM
  #171
Quant's Avatar
2002 CLK55
for brake fluid? its motul rbf600. i'm starting to use mobil 5w-50 this year, will let you know how it works out but i had success in the past with 0w-40 just figured to give this a try as it might be better suited for track conditions.
Old Jul 20, 2020 | 03:25 PM
  #172
Quant's Avatar
2002 CLK55
i dont believe they provided before and after flow chart, i guess dyno would be best indicator of how car is running. currently having issues after rebuild, need to sort that out first.
Old Jul 20, 2020 | 06:48 PM
  #173
Chappy's Avatar
AMG
@Quant
Thanks, I had brake fluid flushed with Motul RBF600 on my 208. Getting a few things updated before a couple of days on the track. 👍
Old Jul 20, 2020 | 09:33 PM
  #174
Quant's Avatar
2002 CLK55
@Quant
nice have fun! btw i had great success with stoptech pads and brake lines, highly recommend those.
Old Jul 20, 2020 | 10:28 PM
  #175
Chappy's Avatar
AMG
Thanks! The only change other than brake fluid is better tires. I went with Pilot Sport Cup 2 in 17s.
Have you explored any of the suspension offerings at this place?
https://rennsportfactory.co.uk/
Some of the options get real spendy, but have me thinking twice....😳🏦🏦🏦🏦🏦🏦🏦😆
