W208 CLK55 M113K Weistec
Old Aug 3, 2020 | 07:05 AM
zwier.z's Avatar
A250 sport
Post W208 CLK55 M113K Weistec
Hello Everyone,
I'm Kinda new to this Forum
Long Story Short,
I have CLK55 W208 '99
current mods:
Engine;
M113K with Forged Pistons/Rods
ARP Head studs
Head Spacer
M113K ECU
Supercharger:
Weistec 2.9L full kit
Trans:
Stock M113K looking to upgrade soon
Eurocharged Tuned M113K TCU
Differential:
Wavetrac LSD
3.06 Ratio Charger SRT ** I modified the OEM Cover to fit this in and I need help with Bearings , which would fit???
Cooling:
Custom Heat Exchanger
CM90 Water Pump
Ice Tank
Fuel System:
Dual 044 Pumps
Nuke Filters
Nuke Fuel Pressure Regulators
Nuke Surge Tank
Injectors currently using Weistec's 650cc I think. Need advice on this one
It's still work in progress
I still gotta do the electric fan/radiator/air intake/exhaust system
and might as well get CF Driveshaft/Bigger Axles
I'm gonna fit in E55's w211 front Brakes
Please,Share your experience to help me with mine
Old Aug 3, 2020 | 03:59 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I had to order the side bearings from 123bearing.com in France.
NP957403-NP120839-TIMKEN
NP604623-NP335170-TIMKEN
I did not remove my pinion gear, so I left that bearing in place; I don't know what its part number is.
Old Aug 3, 2020 | 05:42 PM
zwier.z's Avatar
A250 sport
https://streamable.com/2v38no check the video
yes, those side bearings.
the OEM ones didnt fit after changing the gears to 3.06 of SRT8
Old Aug 4, 2020 | 08:06 AM
zwier.z's Avatar
A250 sport
these parts are meant to fit E55 w211/CLK55 w209
are u sure these will fit w208?
Old Aug 4, 2020 | 05:51 PM
JoeJErnst's Avatar
I don't understand what you're doing. I thought you said you got a W211 diff and put in SRT8 gears.
Maybe I misunderstood, can you explain in more detail?
The bearings I posted are for the W211 (215mm ring gear), they will not fit the W208 diff.
Old Aug 4, 2020 | 06:04 PM
zwier.z's Avatar
A250 sport
I am copying what Blackbenzz did with the differential. the car is w208 clk55. I installed W211 LSD along with SRT 3.06 rear gears.I had to modify the differential cover to fit the parts. now the only issue is the bearing, they wont fit
Old Aug 4, 2020 | 06:13 PM
JoeJErnst's Avatar
Are you saying you put a W211 215mm ring and pinion into a W208 diff case? I don't see how that could possibly work.
Old Aug 4, 2020 | 06:20 PM
zwier.z's Avatar
A250 sport
I think I misinformed you
which LSD did u fit??
Old Aug 4, 2020 | 06:23 PM
JoeJErnst's Avatar
Originally Posted by zwier.z
do u use whatsapp?
+966547801008
No, I don't. Post some pictures and more details here so others can benefit from this knowledge.
FWIW, I have the same setup in my CLK and it uses the entire diff case out of an SRT8, not just the gearset and carrier. It sounds like you are trying to stuff 215mm ring gear in a case designed for 210mm and I don't see how that could ever work. Your pinion depth could never be correct, even if you did manage to get the Wavetrac mounted.
Old Aug 5, 2020 | 05:40 AM
zwier.z's Avatar
A250 sport
ss
u fit 215mm SRT differenttial in ur w208?
how?
I have the full SRT differential untouched and I have wavetrac LSD of w209 clk
how can I fit them in my w208?
Old Aug 5, 2020 | 12:13 PM
JoeJErnst's Avatar
ss
how?
Look at the cases for your SRT8 and W208 diffs. Do they look similar? Do they both mount with one bolt in the front and two bolts in the rear of the case? If so, then you just need some custom aluminum bushings made and the case will bolt right in. Then you need custom axles and re-splined wheel hubs.
You should take the time to read this whole thread: https://mbworld.org/forums/clk55-amg...rsion-kit.html
Old Aug 5, 2020 | 08:31 PM
zwier.z's Avatar
A250 sport
Thanks alot
I will go through it wholly
Old Aug 6, 2020 | 01:50 PM
zwier.z's Avatar
A250 sport
SRT on the right
W208 on the left after porting
