Quick question, will this size and offset fit?
Sounds like they fit on a W210. Not sure of the exact differences between the cars, except for the obvious, 2 extra doors.
18x8.5 et35
18x10 et35
So a 10" won't stick out past the rear fender well ya think? Front also? Again, I'm new to MB's. I will say that you are the most helpful person I've seen on here so far. Thanks for that!
https://stumptownbenz.com/how-to-put...your-w208-clk/
Here is an example of a W208 on 10" wheels.
im lowered on h&r smaller spring pads. Want to put set of CL/S class 18” 8.5/9.5 et fr 44 r 36 on mine.
I’m going to do 12mm front and 15mm rear spacer bringing them to 32/31
i would assume that rear et is similar to yours?
what tires are you running?
All search is discussion between 225 or 235 front. What would you suggest for my proposed setup to eliminate possibility for rubbing?
thanks!
thanks!
Firstly, this is not my car. This is a member's car with SL 2 Piece AMG wheels.
OP asked if these wheel specs fit and I responded.
Check OP's post at the beginning.
