CLK63 Black Series Forum & Registry Information and discussion on the W209 CLK63 AMG Black Series and Registry for all owners.
Brakes
Old Mar 27, 2009 | 06:20 PM
yooker's Avatar
a durr
Brakes
I just have some very quick question for those of you who track the car.
1) What brake fluid do you guys use?
2) Are OEM pads good enough for track days or is there aftermarket pads for the car?
3) How many track days do you guys go to before you replace pad, rotor, fluid?
4) Has anyone warped their rotors doing track days?
Old Mar 27, 2009 | 06:59 PM
DFW01E55's Avatar
'14 ML BT
[QUOTE=yooker;3435103]I just have some very quick question for those of you who track the car.
Stock MB fluid.
OEM pads have been fine.
Only 2 so far, no problems.
Not me.
"Warped" rotors are often mistaken for micro build up of pad material on the rotors. I haven't experienced it with this car, but on others as you drive home and apply the brakes, the shuddering makes you think you've toasted your rotors.
I wait until they cool down, apply water, let them sit overnight, then in the morning on a cold rotor, a couple of quick stabs on the brakes removes all that build up and magically the rotors are unwarped. YMMV
The stock Corsa tires are great too.
Old Mar 27, 2009 | 08:10 PM
SMP's Avatar
SMP
CLK63 Black Series
DFW answered already all the questions. The only difference, I replaced the stock rotors in the rear with two piece rotors. I went up on wheel and tire size and changed the set up on the suspension. I changed the stock paper filters to aftermarket ones, which I highly recommend, especially if you take the car to the track. Unless you run an endurance race, you won't warp the rotors.
Old Mar 27, 2009 | 08:37 PM
yooker's Avatar
a durr
Impressive, I just hope the C63's brakes will be 1/2 as good as the BS's. Plan on taking it to the track in June. The track is notoriously hard on brakes because there isn't a real main straight to cool them down.
Old Mar 27, 2009 | 10:26 PM
alexander stemer's Avatar
CLK 63 AMG Black
On a really tight course, the fronts will fade.
I haven't had the material build-up problem on the BS, but in other cars, i've just stuck it in second and driven with the brakes and gas on. takes about a half mile, then let them cool down. Shudder gone. AS
Old Mar 29, 2009 | 07:51 PM
TTAMG's Avatar
2011 C63
I just modified my front rotors to 15". if anyone is interested i can post some pics. Its a really easy upgrade. also makes the car look much better in my eyes.
Old Mar 30, 2009 | 01:03 AM
Eitan1's Avatar
WHT BS
I would be interested to see what they look like. Please post some pictures when you get a chance.
Old Mar 31, 2009 | 05:14 AM
TTAMG's Avatar
2011 C63
https://mbworld.org/forums/w211-amg/...ml#post3440771
check it out.
