Tire Size for Vossen Wheels...
Old May 9, 2014 | 05:35 PM
BenzCali's Avatar
G-Class
Purchased set of Vossen for my CLS550. The vehicle is lowered as you can see in the picture. I am little undecided in regards to the tires in the rear.
Front: 255/30-20
Rear: 305/25-20
I have been told that choosing 305 for rear will slightly rub and 295 would be the recommanded choice. I read few posts from other members and it seems that they don't have any issues with 305. I personally want to run 305's in the rear and would love to get some opinion or experiences that you might have.
Old May 9, 2014 | 10:51 PM
Masorcas's Avatar
2012 cls550--2012 srt8 jeep--2014 e350--2014 cla 250
If u have a lowering module u dont have to worry about rubbing
Old May 9, 2014 | 11:29 PM
BenzCali's Avatar
G-Class
I do have lowering module. Its just I have a habit of lowering down the car where in the rear the fender covers small amount of the tire. The front, very similar to the rear as well (fender leveled with the tire). So I want to make sure, I keep that set up once the vossen's are set up. Therefore, I want to get the best section width for the front and for the rear.
Old May 10, 2014 | 01:27 AM
Masorcas's Avatar
The vossens are not going to be completely flush with the fenders so 305's should be fine . I have vossen cv7's with 305's and lowered no rubbing at all. Plus when i have people out back the airmatic automatically raises about an inch
Old May 10, 2014 | 01:45 AM
BenzCali's Avatar
G-Class
Thanks for the feedback!
Old May 10, 2014 | 08:04 AM
bigigg's Avatar
14' CLS550
Tell me the offsets and I can help you out..
FYI 305 on a 10.5 wide rear at 42et is fender flush.. as far as rubbing on suspension?? IDK
Old May 10, 2014 | 02:23 PM
BenzCali's Avatar
G-Class
Front: 32et
Rear: 42et
Front 20 x 9
Rear 20 x 10.5
You mean hella flush? I love the look but I really want to avoid doing any fender rolls. Would you recommend 295 for the rear instead?
Old May 12, 2014 | 06:41 AM
bigigg's Avatar
14' CLS550
255/30 and 305/25 with those offsets. you will have no problems.
Old May 12, 2014 | 08:35 AM
threeMBs's Avatar
Only MBs - the best or nothing
+1.
Old May 12, 2014 | 07:30 PM
BenzCali's Avatar
G-Class
Perfect, 255/30/20 and 305/25/20 it is.
Actually I just confirmed my front wheels are +25 but I am not worried about my front tires. I will still go with 255/30/20 and still slam it.
Thank you!
Old May 13, 2014 | 07:05 AM
bigigg's Avatar
14' CLS550
you will still be fine with 255/30 25et
Old Jun 5, 2014 | 03:24 PM
whoadude's Avatar
CLK63BS, 991 C2S, F86 X6M
Thank you!
So did you actually get the 305s on the car? How did it work out?
Old Jun 5, 2014 | 04:43 PM
bigigg's Avatar
14' CLS550
He went with 295's
Old Jun 5, 2014 | 07:15 PM
whoadude's Avatar
So 305s will rub?
Old Jun 5, 2014 | 07:26 PM
BenzCali's Avatar
G-Class
Originally Posted by whoadude
So 305s will rub?
A lot of the members said that it will not rub. However, I do slam the car at times and therefore I went with 295s. Spoke with Vossen Wheels before purchasing the tires and they said if you slam the vehicle its better to go with 295s. If you do go with 305s, let me know how that works out.
Old Jun 6, 2014 | 10:51 AM
mJstk01's Avatar
Does the speedo require any calibration to accommodate these tire size changes or are these close enough to stock diameter?
Old Jun 6, 2014 | 12:40 PM
bigigg's Avatar
14' CLS550
same as stock if you use op's tire sizes
Old Oct 11, 2015 | 12:09 PM
mJstk01's Avatar
Is there software that will allow us to calibrate speedo on our car if we run larger tires?
