Build the most powerful cls550 4matic
Old Nov 15, 2016 | 02:20 PM
  #76
gardevski's Avatar
cls63 amg pp 700hp, ml63 amg w166 700hp, cls550 4matic 720hp
Also the car wants to shift at about 6k rpm and you can see it on the chart 😀
Originally Posted by gardevski
Hi All,
Please find attached the long waited dyno sheet of my CLS500 4matic
Old Nov 30, 2016 | 03:00 PM
  #77
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Hi All,
Also the car wants to shift at about 6k rpm and you can see it on the chart ��
I am really interested to see the 1/4 miles now of this beast!!!
Old Dec 8, 2016 | 04:54 PM
  #78
gardevski's Avatar
Will check the 1/4 time next year Now i'am installing Aquamist hfs4 meth injection and expect to go over 780-800hp will update after the install is completed.
Old Dec 15, 2016 | 04:03 PM
  #79
TTMerc's Avatar
2014 CLS63 S
This is AWESOME! Do you know what boost you're making or have a log with the dyno? Did you have to change out the MAP sensors for more boost?
Old Dec 15, 2016 | 04:54 PM
  #80
gardevski's Avatar
Hello, The boost is 2.5 bar (absolute pressure) and this is the limit of the map sensor. For DD the car is great.
Old Dec 20, 2016 | 02:33 AM
  #81
TTMerc's Avatar
2014 CLS63 S
Holy hell your getting 36 pounds out of those turbos?? or just the map sensors are 2.5 bar?
Old Dec 20, 2016 | 02:20 PM
  #82
garrettg's Avatar
GLS450
If at sea level that would be around 22 pounds of boost from the m157 setup if higher elevation than slightly higher boost as the map sensor has to account for both atmospheric pressure as well as actual turbo boost beyond that. I believe that is still roughly double of what the M278 turbos can put out, which is impressive.
Old Dec 21, 2016 | 03:01 PM
  #83
TTMerc's Avatar
2014 CLS63 S
That makes total sense! Thats Beastly!
Old Dec 27, 2016 | 06:01 AM
  #84
gardevski's Avatar
Hello,
I have successfully installed the Aquamist HFS4 water/meth injection as well as two oil coolers on both left and right side of the front bumper. The Meth is the best upgrade power/cost that i have installed. The timing is advanced as much as possible, no knocking and the power is close to 800hp crank. Will dyno the car next year. Just for information 100-200 is about ~6 sec. Compared to my CLS63 amg PP that is 700 hp it's ~ 6.8 sec
Old Dec 28, 2016 | 04:51 AM
  #85
cocobeex's Avatar
Hello,
Thats unbelievable...
Would you share the parts you bought and have done ?
But are you able to help out for the ECU tuning if its shipped to you ?
Old Dec 30, 2016 | 03:55 PM
  #86
gardevski's Avatar
Thank you for your request. Yes i'll share all the parts needed when i have more time. Some parts are required some not (there was no info as this is the first build m278)
Here are some pictures of my cooling setup including the two oil coolers at the front and the Meth in the trunk (pictures taken while installation in progress).
The bottom line: I have invested ~17-20k USD in the build. If i build it again will go under 13-14k as some parts are not required (same as the m278 engine). The most expensive are the M157 turbochargers that you can get as low as 4-5k second hand (they need to be less than 30k miles) and new up to 10k, ECU tuning about 2-3k (few sessions included), intercooler system upgrade 1.5k, Aquamist hfs4 1k, oil cooler upgrade (not needed if your engine is equiped with oil cooler from the factory) 1k including the oil lines and AN10 hoses and AN10 fittings, Exhaust system, full dual 3 inch from the turbochargers to the mufflers 4-7k. Turbo-back downpipes are required (for example my cls63 fell off a cliff after 5.8k rpm -100hp till redline due to restricted flow of the stock turbo-back downpipes), Quaife LSD 1.5k, AMG front and back brakes (required!!) 3k. Labor for engine removal (turbocharges installation) 380 USD here in Bulgaria LOL.. All other installations except the ECU tune are performed by me including the build of the exhaust, downpipes (including 3d printing and 3d design), meth installation, cooler installations etc..
Overall i preffer this car over any rear wheel drive 700hp+ AMG
Will check for the ECU tune and will let you know.
Old Jan 1, 2017 | 05:54 PM
  #87
Dueclaws's Avatar
'12 E550C, Sierra Denali
Impressive!
Old Jan 2, 2017 | 02:56 AM
  #88
cocobeex's Avatar
So, the Quaife LSD can be installed without any tweaks ?
Is it the Qualife AMG LSD you installed ?
And what year is this CLS550 ?
Old Jan 2, 2017 | 03:00 AM
  #89
gardevski's Avatar
The car is 4matic with Quaife LSD installed on the rear and now it's blasting off the line. The best was 2.9sec 0-100 km/h
You can install LSD on 4matic with zero problems with traction control. The car is much more stable and predictable. Also you put all the power to the ground.
This car is 2013 EU version with all possible options included. Including carbon fiber trim same as cls63 amg that was optional when ordering the car (i think it's not available in any other 550 series)
Happy New Year!!
Old Jan 2, 2017 | 03:06 AM
  #90
cocobeex's Avatar
Happy New Year!!
Happy 2017!!! to your new built beast!!!
wow...2.9 sec 0-100km/h
That is insane.
I have got a pair of M157 Turbo here, waiting to be installed.
If mine has oil cooler already.
I should be able to just bolt on these turbos on my M278 engine.
I will also need new gasket and copper nuts.
Is that correct ?
Who tuned your ECU ?
Would I be able to jsut have the same file into my ECU to get close result ?
Old Jan 2, 2017 | 03:12 AM
  #91
gardevski's Avatar
That is insane.
Is that correct ?
Thank you! Will check with the tuner if he can provide the files for me (as they keep them for the record) and will let you know. Yes you need only the turbocharger manifold gaskets and the copper nuts. All oil and water lines will fit right away to the new turbochargers. Expect 680-700+ hp with just the turbo swap and ecu tune.
Old Jan 2, 2017 | 03:19 AM
  #92
cocobeex's Avatar
Yea, that is exactly one of the person who had done this project few years back said the same thing.
He told me, it achieved 600WHP.
Is yours WHP ? or to the crank ?
Old Jan 2, 2017 | 03:42 AM
  #93
gardevski's Avatar
The power on the wheels was 650 AWHP before the meth injection. Now is close to 700 at the wheels (will dyno the car in the upcoming month due to the bad weather)
Old Jan 2, 2017 | 06:25 PM
  #94
cocobeex's Avatar
Yea, same here...bad weather....snowing like non-stop.
Btw, would you be able to share what is the part (model) number for the Quaife LSD ??
Thank you.
Old Jan 5, 2017 | 10:57 AM
  #95
gardevski's Avatar
Thank you.
Hello,
The part number is quaife 21833205312
Old Jan 5, 2017 | 11:00 AM
  #96
gardevski's Avatar
And last some interior pictures
Old Jan 5, 2017 | 01:30 PM
  #97
TTMerc's Avatar
2014 CLS63 S
Looks great! I miss my column shifter so much.. The AMG shifter on the console and leaving everything else the same was a mistake. When you put a cup or two in the cup holder you cant even get to the temp buttons or anything under the volume for that matter! This is a perfect setup AMG power (and more) with the simple things of the 550. Oh and also the adjustable ride height I miss with the 550
Old Jan 5, 2017 | 05:20 PM
  #98
cocobeex's Avatar
Hello,
Thank you bro!!!!
And I guess I have to go with E500 model ? (because I have got E550 4matic)
I found this
http://www.birdsauto.com/parts/21233218360
And, I am wondering,
Is it a big difference ? just upgrade to this Quaife DIFF ??
Old Jan 6, 2017 | 02:44 AM
  #99
gardevski's Avatar
Thank you bro!!!!
I found this
Yes, this is the correct part. The difference in big and car is completely different when you floor it. Also when overtaking and accelerations in corners it just go. In snow is even better.
Old Jan 26, 2017 | 02:06 PM
  #100
software's Avatar
2014 E550 Convertible
Hey cocobeex did you get the turbos swapped? If so how did it go and what was required? I could tolerate more pwr in the 14 E550 cab - just exploring options now.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
