Build the most powerful cls550 4matic
Old Mar 25, 2017 | 05:04 PM
  #151
gardevski's Avatar
cls63 amg pp 700hp, ml63 amg w166 700hp, cls550 4matic 720hp
I think in the next 1 month it will be ready. Will keep you informed.
Old Mar 26, 2017 | 10:14 PM
  #152
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
I will follow your post where ever you go
I am keeping my car for long term.
I might also follow your turbo mod. Push it to max.
Btw, Is your ECU tuned with Meth injection ??
Is there any risk on meth injection ??
If i add meth injection in my car without new tune. Will it still work ??
Old Mar 26, 2017 | 11:10 PM
  #153
TTMerc's Avatar
2014 CLS63 S
Awesome to see these builds going strong!!
Would you guys care to post any pics of your meth setups? I've had mine sitting in the box and now that its getting hot need to install!
Old Mar 27, 2017 | 01:18 AM
  #154
squantum1's Avatar
2014 CLS550 4Matic
Originally Posted by cocobeex
Hey bud
How's your going ?
I'm having some issues with fuel delivery. So far i have been unable to get the passenger side AMG fuel pump to run off the stock controller. I decided to get the tuning done with the stock fuel pumps. I can only go about 3/4 throttle before my fuel pressure starts falling off. On a positive note though, it's still much faster at 3/4 throttle than the original turbos were at full throttle. If i could just get that pump too work....
Old Mar 27, 2017 | 02:05 AM
  #155
TTMBCLS's Avatar
cls550
changing to the amg fuel controller is my concern too..
Old Mar 27, 2017 | 02:44 AM
  #156
TTMerc's Avatar
2014 CLS63 S
If I were in that situation I would try a boost a pump. I've used them on other applications with success. You can make the boostapump come on using either rpm, load, map, aux window switch or even a momentary switch. There's a couple company's out there that make them. I think mine was a kenne bell but there's other better more sophisticated versions out there now.
Old Mar 27, 2017 | 03:16 AM
  #157
cocobeex's Avatar
Sorry to hear that AMG pump is not working at this moment for you.
gardevski has done it. He might know the answer to this issue.
I wonder if its CLS has this issue.
The tuner told me stay with my E class stock pump.
So, i didn't upgrade it to AMG pump.
And yea, the power is unbelievable!!
Its a totally different car.
Even 60-120mph runs like a rocket!!
My only problem is LSD, it has clunk click sounds.
My tech said it will be gone after few weeks.
Old Mar 27, 2017 | 09:48 AM
  #158
mJstk01's Avatar
Nice thread you guys have going on here...was there anywhere in particular you guys bought all your parts (e.g. m157 turbos, amg pump, etc...)?
Maybe unrelated, but I had a LSD (peloquin) put into my VW long time ago and it experienced a similar clunking / clicking noise you're describing at only low speeds. To my understanding, it was a result of high spots on the ring gear from putting the LSD in with a press and hammer. The tech said the noise would go away, but it took more or less many months to completely fade away.
Old Mar 27, 2017 | 12:31 PM
  #159
gardevski's Avatar
Hello, will check my wiring and make some pictures as it was pita to make it work. Please note as there are 3 or 4 wiring diagrams for the fuel pumps (even with same relay/controller). Also if the pump do not run try to switch two of the wires that powers the motor. Did you install Ground to the chassis? Let me know.
Old Mar 27, 2017 | 12:43 PM
  #160
squantum1's Avatar
2014 CLS550 4Matic
Hello,
I have retrofited the AMG fuel pumps with success. Used the original Fuel pump controller but rearrange the wires to be able to run the pump. No more fuel pressure drops under any load. Will schedule dyno session in the next 10 days to see the final result. The car is very very fast 0-200km/h under 10 sek.
Gardevski i sure could use your help. I have attatched pictures of the AMG fuel pump and the harness that connects to it. You mentioned an extra ground needing to be added to run the pump and possibly the switching of a couple of wires around. So far i have not been able to get it to power on. The wires are currently in the order as received from the factory. Based on the pics can you guide me through the correct way to do this? This pump has me at its mercy!
Underseat Harness and Fuel Pump Cover Connector
Fuel Pump Cover From Bottom Along with Fuel Pump (factory wiring order)
Old Mar 27, 2017 | 12:50 PM
  #161
squantum1's Avatar
2014 CLS550 4Matic
Thanks for the help! Where does the chassis ground need to be connected to in the pics I attached in the previous post?
Old Mar 27, 2017 | 12:57 PM
  #162
gardevski's Avatar
I'll have to search my old phone for the pictures as i have made some when installing it. The wires need to be rearranged but dont remember which one went to ground. The one that need to be on Groud to chassis (i think it was the brown) must not be connected in the pump. So you will have 3 wires (thick one) go in the pump and the one from the top plug directly to the chassis ground in the trunk
Old Mar 27, 2017 | 01:13 PM
  #163
gardevski's Avatar
I checked and here is how my setup looks like (not sure the wires are same pattern inside the pump but they must be) The brown is cut from the controller and extended to to the trunk (ground to chassis)
Old Mar 27, 2017 | 01:15 PM
  #164
gardevski's Avatar
Will check for another photos that include the internal wiring setup
Btw if you use the stock pump on the passenger side (the e550 pump) and the AMG regulator on the driver's side it wont work good. The Driver's side is pressure regulator. You have to use the pump paired with it's pressure regulator.
Old Mar 27, 2017 | 02:48 PM
  #165
squantum1's Avatar
2014 CLS550 4Matic
When i disconnect the harness from the fuel pump and test the brown wire, it shows it's already connected to chassis ground on my harness. Should i cut it anyway and run another ground to the chassis?
Old Mar 27, 2017 | 03:48 PM
  #166
gardevski's Avatar
I must double check first to be sure.
Old Mar 27, 2017 | 04:47 PM
  #167
squantum1's Avatar
2014 CLS550 4Matic
Ok. Thanks.
Old Apr 3, 2017 | 12:06 PM
  #168
squantum1's Avatar
2014 CLS550 4Matic
Not trying to be pushy, just checking in to see if you were able to find pics of
or check the wiring order inside the tank for the 63AMG fuel pump. I'm still
stuck until i figure this out. Thanks.
Old Apr 3, 2017 | 03:57 PM
  #169
eLs13's Avatar
E550
Hey just curious on the update on the Quiafe rear LSD is it quieting down some or it could be bad install?
Also I checked around Quaife website and I see different part numbers for w212 e63 LSD which states 4matic front.
Could it be front LSD that can bought and used?
Old Apr 3, 2017 | 06:21 PM
  #170
cocobeex's Avatar
My LSD turns out to be properly installed.
The noise is not from LSD, it is from the Exhaust Pipe.
At the end of it, was kinda loose.
There is no noise from LSD actually.
It makes huge difference in cornering. Its so smooth when cornering now.
Old Apr 3, 2017 | 10:57 PM
  #171
squantum1's Avatar
2014 CLS550 4Matic
My AMG fuel pump was defective new out of the box. Replaced it with another and got it working after switching a couple wires around. I spent soooo much time trying to get a dead pump to work My car is finally running as it should. Power delivery is VERY STRONG, wide open throttle acceleration is breathtaking. Now the 550 means buisness! Thanks to Gardevski for starting this thread, Cocobeex for getting me out a pinch, and everyone else who has contributed. Love this car now!
Old Apr 3, 2017 | 11:55 PM
  #172
cocobeex's Avatar
Glad that you got it working!!!!!
Now, you will smile whenever you sit in it.
When you go WOT...you gotta hold the steering wheel real tight.
My buddy almost pee in his pants when he was on the passenger seat during WOT.
Enjoy the new power and drive safe!!
Old Apr 24, 2017 | 11:15 AM
  #173
eLs13's Avatar
E550
So doing some research it seems kleemann makes a front lsd for this platform amg models. I also see Quiafe as well makes one for front.
http://catalog.kleemann.dk/catalog/c...nn-lsd-4matic/
http://www.*********.com/content.php...ential-upgrade
Has anyone installed a front lsd on their cars?
Old Apr 28, 2017 | 12:17 PM
  #174
eLs13's Avatar
E550
I guess nobody knows above?
Old May 1, 2017 | 06:49 PM
  #175
laynlow's Avatar
2015 CLS550
Interested in the methanol injection as well.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
