possible alignment problem ?
Old Mar 5, 2020 | 12:25 PM
Dblok1113's Avatar
2014 CLS 550
Ran over a piece of pvc plastic and gotta flat went back to discount tire and they replaced tire but told me on both my rears I have something wrong because the inside of both rear tires are worn really bad especially for just purchasing the tires. The fronts are perfect, So I attached a picture of the wheel to show the wear from the old tire and the wear is pretty much Identical on the other tire I had to order another one bc the threads are about to come out. I called the Mercedes shop that does the Maitenence on my car and they said it could be alignment so I want to know if anyone else has had this problem with their tires,
thanks guys !
Old Mar 5, 2020 | 05:23 PM
Tbbt CLS's Avatar
2013 CLS550 4Matic OE Tuned
Check out this site, many people are experiencing what you have. I think a good alignment shop or a good dealer will be able to help you. Marv
www.k-mac-camber-kits.com
Old Mar 5, 2020 | 05:29 PM
Dblok1113's Avatar
2014 CLS 550
thanks Marv I appreciate it I will have the guys at my shop give it a look it on Tuesday is their next available I have to get get a service a3 as well so might as well get it all done.
Old Mar 5, 2020 | 05:41 PM
Tbbt CLS's Avatar
How many miles on those tires? I can't read the brand either. Marv
Old Mar 5, 2020 | 06:41 PM
Dblok1113's Avatar
2014 CLS 550
I put up a post when I bought them I guess it was October and they are the yoko advan sport
Old Mar 5, 2020 | 08:18 PM
Roop94's Avatar
W218 Stage 2, E85
It could be the alignment, unless you have your car lowered quite a bit. How many miles have you put on those tires?
Mine are getting there too, but I have mine lowered at least 1.5 inches, so I know it's the camber that's killing the inner thread on them. My last tire that went flat had the wires showing lol the outer thread was fine.
Old Mar 5, 2020 | 08:34 PM
Dblok1113's Avatar
2014 CLS 550
mine is not lowered but I only drive the car in sport mode on both ,drive mode and suspension I don’t know if that matters but I know sport suspension is lower than the comfort suspension I believe . I have about 7,000 miles on them
Old Mar 5, 2020 | 08:45 PM
Tbbt CLS's Avatar
I'll take at my Contipro contacts tomorrow, I have about 10K on them. I'll post up a picture for comparison purposes. Marv
Old Mar 5, 2020 | 09:09 PM
Roop94's Avatar
W218 Stage 2, E85
Then it seems like alignment or something else that is causing the uneven wear. 7k miles is pretty low. Mine is lowered where the fender is covering just a little bit of the tire...so it's pretty low than stock. I have about 5-6k miles on mine.
Sport mode doesn't lower enough to give that much wear. What I would suggest is to simply replace the tires and get an alignment done. At this point, you need new tires anyway. That's too much badlness for 7k miles on a tire. Also, what is the treadwear number on the tire? The lower the number, the quicker it'll wear out. Mine is rated at, I think, 240-280. Same tires I ran on my older W211 and they'd last me abt 7k miles and I would flip them inside out and another 3-4k miles before they go bald. Mind you, my W211 was just as lowered as my W218 or even more closer to the ground. Front tire was completely tucked in and almost the whole tire in the rear as well.
Also, it matters the way you drive. Since they come neg camber stock and you do too many hard pulls/burnouts...then the number of miles would be out of the equation.
Old Mar 5, 2020 | 09:27 PM
Dblok1113's Avatar
2014 CLS 550
cool and I ordered another tire anyway and I will be having my mechanic check out suspension when they do the a3 service, they recently did a b service on it at 100k i wasn’t sure if they checked out suspension or not. I’m not to good mechanically so when it tells me to service Vehicle I just trust it and take it there and pay whatever it is lol but I would think when they looked over the airmatic suspension they might of seen something but I guess not. I’m hoping they can see what it is, i wasn’t so fond of the tires due to the fact they were fairly new and even with light rain at red light I was really spinning the tires and I was being light on the gas as well which is why I didn’t think the tire was that good considering the feeling of a lack of traction. But maybe if it is an alignment issue that gets fixed might be a better tire in the rain when riding properly aligned. I do trust the mechanic will be thorough in what they are going to do to inspect it but I love coming here to get some real life comparisons!
