Cls550 2013 4matic ( rear radar sensors )
Old Jan 13, 2021 | 05:47 PM
emazens's Avatar
C230 02, gl320 09, e550 convertible 14
Hello ,
can someone help me please to find out if these radars would fit and work on my cls550 2013 4matic
Old Jan 14, 2021 | 08:53 AM
konigstiger's Avatar
'71 Pinto
VIN?
Old Jan 14, 2021 | 09:03 AM
emazens's Avatar
VIN?
WDDLJ9BB1DA068200
Old Jan 14, 2021 | 09:14 AM
'71 Pinto
That part is not compatible search 0009062000 (used) or current 0009050110 used/new.
File Type: pdf
Old Jan 14, 2021 | 09:24 AM
emazens's Avatar
These are for the back ones right ? For the blind spots ?
i really appreciate ur help
Old Jan 14, 2021 | 11:35 AM
'71 Pinto
Yes.
File Type: pdf
Old Jan 14, 2021 | 11:36 AM
emazens's Avatar
Thank you very much
you are the best
Yes.
Old Jan 20, 2021 | 03:45 PM
Petar Kremenski's Avatar
Hello !
I also have the same issue with my blind spot assist
Could you please help me find the correct part number ?
VIN : WDD2183931A080632
Thank you
Old Jan 20, 2021 | 03:58 PM
'71 Pinto
Same part #s.
File Type: pdf
Old Jan 22, 2021 | 11:09 AM
Thank you @konigstiger !
I took out both sensors and and i saw that the part numbers are #a0009050110
And another question if i find two sensors with 0009062000 will they actually work on both sides ?
Thanks again !
Old Jan 22, 2021 | 12:22 PM
'71 Pinto
Current part # 0009050110 same for both sides.
Old Jan 23, 2021 | 10:13 PM
Marxbenz's Avatar
CLA45 AMG
Thanks again !
are you still looking for these radar sensors? 0009050110
Old Jan 23, 2021 | 10:38 PM
emazens's Avatar
i am trying to figure out where to get the best price ( dealership prices is pretty high here )
also will need to get the wire harness to plug them ( mone got corrosion
Old Mar 23, 2021 | 12:13 AM
emazens's Avatar
If i find one that came off a cls63 2015 i think part a0009052504 it would work ?
Old Mar 23, 2021 | 04:15 AM
Marxbenz's Avatar
CLA45 AMG
No it wouldnt work.
Old May 31, 2021 | 11:13 AM
Dc3tech's Avatar
2013 glk250
Radar sensor question.
Hello all I have another question. So I have a 2013 GLK 250 and the rear radar sensor corroded. My part number is 0009050110. I have a couple used good ones that are part number 0009054503 out of a 2014 Glk. Would anyone be able to tell me if these would work? I have blind spot assist and adaptive cruise on my 2013. Any information on these would be greatly appreciated!
Old May 31, 2021 | 11:22 AM
'71 Pinto
VIN?
Old May 31, 2021 | 11:24 AM
Marxbenz's Avatar
CLA45 AMG
4503 is compatible with 2014 GLK 250 ONLY you can try it but your system will not recognize it and or it will be inoperative
Old May 31, 2021 | 11:27 AM
Dc3tech's Avatar
2013 glk250
Is there any way to have them programmed to work? Do you know of any alternates to the 0009050110? Where are you getting this information from? I just like to know as anything will help for future troubleshooting/maintenance. Thank you so much for the reply!
my VIN is WDCGG0EB8DG124447
Old May 31, 2021 | 01:49 PM
'71 Pinto
As mentioned you can only use 0009050110 = 2013 (803), 237 active blind spot assist; 4503 = 2014-2016, 234.
File Type: pdf
