MB is extending warranty for Exhaust valve assy
Old Apr 5, 2023 | 01:58 PM
rumb's Avatar
cls550 2014
Just got a letter from MB MB extending warranty for Exhaust valve assy. googled it and found nothing.
Anyone know what this is?
applies to certain 2011-2016 V8 engines.
Old Apr 5, 2023 | 03:33 PM
DigitalDisaster's Avatar
2013 Weistec 540/715 tuned CLS 550, 2008 E350, and '07 Jaguar S-Type R
By your profile, I am assuming the warranty covers the M278 engine. Does it list VIN or motor numbers covered? Are you the original owner?
Old Apr 5, 2023 | 05:07 PM
rumb's Avatar
cls550 2014
cl/cls/s/e/ml/sl/g/gl/gle classes V8
It extends the warranty from 50K miles to 120K miles and 10-12 years
Old Apr 6, 2023 | 01:13 PM
rick hesek's Avatar
2014 CLS550
I received the same letter and it applies to the M278 engine.
My 2014 VIN is A092606. Extended warranty to 10 years or 120k miles, whichever is first.
Exhaust valve assembly malfunctions and throws a misfire code.
I am inclined to have this corrected but will get an estimate first.
Rick
Old Apr 6, 2023 | 03:00 PM
rick hesek's Avatar
2014 CLS550
It wasn't obvious to me in the letter, but after talking to a service advisor at my dealer, this is nothing more than a warranty extension.
While in the extended warranty period, IF the exhaust valve assembly becomes a problem, throwing a misfire code, etc., MB will correct it.
No action required until then.
Rick
Old Apr 6, 2023 | 06:44 PM
W205C43PFL's Avatar
Thanks OP for this information.
Old Apr 8, 2023 | 02:29 PM
BobG-MB's Avatar
2014 Ford Edge, 2021 GLE450W4, 1967 AH 3000, 1988 BMW K1000
Rick
2013 CLS550 4Matic
Where is this "Exhaust Valve Assembly" located?
What is its function or what is the malfunction?
What is the repair?
Thanks,
BobG
Old Apr 8, 2023 | 03:00 PM
rick hesek's Avatar
2014 CLS550
Originally Posted by BobG-MB
2013 CLS550 4Matic
What is the repair?
Thanks,
BobG
I believe it is the exhaust gas recirculation (EGR) valve. it basically re-routes exhaust gas back through the combustion process to further reduce raw emissions.
When it fails, or malfunctions, it causes a rough idle and will trigger a check engine light with an "engine misfire code", P0300-P0308.
My dealer service rep stated that it is part of the emissions system and is located withing the cylinder head, vs external.
I expect the repair is a replacement and is labor intensive due to its location.
This letter also states that a reimbursement may be available if you own an M278 engine and have had this work done, previous to this extended warranty.
A 1967 Austin 3000? Sweet!
Rick
Old Apr 9, 2023 | 07:41 PM
W205C43PFL's Avatar
Rick
Looks like there is more information in this thread: https://mbworld.org/forums/s-class-w...-addendum.html
Old Aug 21, 2023 | 06:29 PM
wireman218's Avatar
2022 GLC 300 4 MATIC
Just got the letter for my 2021 GLB 250. Covers 2019-2022 CLA, GLA and GLB vehicles. Says exhaust valve system.
15 year, 150,000 mile warranty. I believe the GLB has the M260 engine.
Old Aug 23, 2023 | 09:42 AM
skullbox15's Avatar
2014 C63
I got one for my GLB as well yesterday. I didn't know anything about that issue. I was hoping it was for the issue with leaky valves... I think Canadian owners have received them but no luck here in the US yet.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
