Illuminated Door Sills Instructions & other small mods
also did a few more smaller updates to the look.
the pic is from after Itapped into the wires going into these lights. just google "how to splice or tap into a wire" if you dont know the right way.
Black cable from the sill is negative and goes to the brown wire and red cable from the sill is the positive that goes to pink/yellow cable.
the cable extension are connected together for each sides front and rear sills. so make sure you work out the length of the cables. short black and read cable connector connects to the front sill and the long read one connects to the rear sill.
P.S. - The install will be much easier if you dont have your dog helping out with the wiring as you can see from the pic.
dont worry its all plastic and you dont need to save any of it after you remove it. i didnt save any of the plugs under it either. clean the tape residue as much as you can. again very tedious and boring.
pic 1 - before.
pic 2 - after removing the sill and lots of sweating
pic 3 - totally worth it result.
Same wiring procedure.
one of these is the pic of the connector that comes with the sills just for your reference.
the final result pic form the above step and the below step show the one problem i faced. there is no place or way to hide the wire coming from teh sill over to the under side panel running along the side of the car frame going to the courtesy lights. so it shows up as a black wire going over as shown. i have ordered small patch of chrome strips to tape over it perpendicular to the chrome strip that already runs along the plastic beige panel on the bottom. i will attach pics of those as soon as i get this done.
