Seating position question for taller AMG GT drivers
I am 6 foot 4 inches tall, so I lowered the seat as much as possible and raised the steering wheel as much as possible. I still found that the top of the steering wheel was partially obscuring my line of sight to the top of the center rectangular information display. For instance, I had to dip my head a little to see what gear I was in when shifting manually.
Are other tall drivers able to get around this by changing either the seat recline or seat bottom rake? What I am trying to determine is that if I had time to fiddle with a bazillion seat adjustment permutations, is it likely that a kinda tall guy like me could find and store a seating position that would give me complete vision of the critical gauges?
Thanks to all for any constructive input offered. Best regards.
Rob
I’m only 6’ tall but do occasionally wish I had more seating position ‘choices’, meaning being able to move the seat further back without the seat back automatically becoming straighter. I have a friend at work who’s 6’2” and more ‘portly’ than me and he simply can’t fit in the car.
Bottom line: get to a dealership and spend plenty of time with the seat controls prior to a purchase since you’re 6’4”.
Bish
are you able to hit the back of the cockpit with the seat? My car constantly adjust the seat on its own and limits/reverses the movements when it gets close. I feel that there’s still clearance but the seat limits how far it can go. Maybe if I turn off esp and set traction control to 9 it’ll let me move the seat more?!🤣
Thanks.
6’4 Too Tall? Mercedes AMG GT C Car Review- Question: Do you fit ?? Big Gulp Exotics
Rob
I feel as though there's got to be some mechanical adjustment of the available range or something. I'm only 6" tall but need the seat all the way down and tilted relatively far back for the screen to not be partially obscured by the top of the steering wheel.
as a noob, I am in the same boat. I got my car Monday, and during the test-drive of a different GTs I was not paying attention. This is my situation. 6'4" with 34-36" inseam. long neck. I am considering an aftermarket digital dash or HUD, especially if I track it. Sure do wish there was an aftermarket digital dash that would just display on the center screen. That would rock. Not wanting to put sticky double-sided tape on my leather dash....
My new thing to try is to tilt the wheel down so I can see the top edge of the gauges, so I can at least sort of tell what I am doing The steering wheel almost in my lap, but not a horrible sterering position. Seat is all the way down, all the way back to the back wall. No combo of lowering or sliding FWD so I can gangsta lean back, will allow me to see the gauges properly. I am probably just going to deal with it. I like the car for lots of reasons, otherwise. I "am" considering taking the seat out and exploring whether there is any room to cut/re-weld the seat rails to gain an inch or so. Probably not.
https://mbworld.org/forums/general-m...el-blocks.html
