GT Fog Lamps ?
Old Sep 17, 2020 | 02:45 PM
SLcruzen's Avatar
300sl roadster
GT Fog Lamps ?
I had a 2018 GTC and now a 2020 GTR. I'm in an area that has fog from time to time.. Last evening I was in fog that had maybe 100' visibility. With low beams on, there was just a mostly white wall in front.. I had looked at the owners manual for "fog lamps" in the past and did again this morning.. There simply is no choice of headlamp function other than low/high beam.. I guess I'm a little bewildered that M/B would spend so much attention to safety and yet delete the fog lamp function from the car.. Even my 58 300SL has fog lamps ! I guess I missed the warning message for not driving a AMG GT product if there is a chance of FOG ! Just park it and wait it out !
Old Sep 21, 2020 | 05:29 AM
SpokenHands's Avatar
2018 AMG GT-C Roadster; 2018 Range Rover Velar;
I own a 2018 GTC and was surprised there is no fog lamp(s)
Likewise i find my car did not have an automatic high beam headlamp.
It appears to be only manually engaged when appropriate
Old Sep 21, 2020 | 01:18 PM
thecutter64's Avatar
2018 Solarbeam Yellow AMG GTS
The car is not practical. I never drive in any inclement weather.
Old Sep 21, 2020 | 01:32 PM
California John's Avatar
2022 AMG SL63
My car has "adaptive highbeams" - which is what MB calls automatic switching. I have a 2018 GTC. My car automatically switches. This is from the owner's manual.
Old Sep 22, 2020 | 12:33 AM
Rocketman84's Avatar
2018 AMG GTS, Ferrari 348TS, 308GTS
Can this be turned off? It's too sensitive, I'd rather switch it manually.
Old Sep 22, 2020 | 04:50 AM
Thanks John, I guess I just got used to the excellent lighting and didn't realise it was adaptive
My wife drives a Range Rover which is equipped with the new Laser Light Headlamp unit (it activates only above 50mph, in an Adaptive setting, is designed to exclude opposite drivers, etc) which lights up the road at least 500 mtrs (kid you not!!!) and is crystal sharp. Brilliant and I am sure will be coming to all sensible premium cars soon. ish.
Old Sep 22, 2020 | 11:05 AM
Skilly's Avatar
2020 McLaren 720s Spider
this is switched on and off with the turn signal stock. Normal position and its not active; push the stock forward and it turns it on. That said, I don't think you can activate the 'high beams' (NA slang) without pushing the stock forward, unless you are flush flashing in the moment (pulling the stock towards you in its normal setting).
Old Sep 22, 2020 | 03:34 PM
2022 AMG SL63
Download the owner's manual and then you can answer these questions on your own - plus find lots of other good tips. Navigate to 2018 and then find your own model.
https://www.mbusa.com/en/owners/manuals
Old Sep 22, 2020 | 11:40 PM
I can get the instant on, where you pull it back temporarily. Played with the stalk a little bit recently and couldn't change modes to non-auto. Will look at my manual for details, thought I'd ask since it came up - thanks.
