Cabin air filter DIY?
Bentley Continental GT; AMG GT
Yes,
I did the change with the car on the ground (but a lift would make it nicer). I used a hand mirror laid on the floor and worked it looking through the mirror.
There are three very small torx sheetmetal screws to remove. These are so small that you probably could use a phillips screw driver too. If you're looking for the screws through the mirror, you'll see 4 but only 3 need to be removed to free a flexible fiber preformed panel that comes out pretty easily once the 3 screws are removed. Two of the 3 screws are along the glove box edge, one at the corner close to the console, the other midway. The 3rd screw is right at the curtesy light.
Remove these three then removing the flexible preformed panel is pretty intuitive. It has tabs on either end that get tucked in then the screws hold it in place. When the cover is removed, you'll see the end of the filter with a sliding plastic locking piece. Just slide it over (to the left if I remember) to unlock it then the filter will come out. It's a bit of a snug fit.
Here is the filter I bought (either Amazon or Rock Auto, can't remember)
Looking at the filter in place you'll see the end of it. There is a directional arrow that points towards the passenger's door.
The new filter kinda stuffs in and you'll have to figit with the plastic locking piece to get it to lock in. The way the filter is designed, it is made to seal along its top edge and sides with a collapsing plastic edging, requiring you to have to put a little pressure upward on it while locking the plastic piece in place.
After that just work the flexible panel back in place and replace the 3 screws, done.
All of this is contingent on age and how flexible you are, A "few" years ago I would have done this in about 15 minutes...it took me 30; but, in another handful of years and I won't be able to do this at all...I'm hoping not....
Surge (05-05-2021)
I took two more pics setting up the mirror on the passenger's floor and showing the 3 screws. They are T20 screws.
The screw by the curtesy light and the one midway along the glove box bottom edge are shown here:
Here are the two in the corner by the console and along the glovebox edge. One gets removed, the other does not.
You can see part of the white plastic sliding/locking piece of the cabin filter right behind the flexible panel in this pic
The hardest part way laying a quarter of my body on the door sill. But I got
it done
it done
Acta_Non_Verba (05-05-2021)
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
This is great, thank you!
Aside from saving $, the other reason to get this done DIY is so a greasy/dirty service tech doesn’t crawl through your car!
I love my service tech, but they don’t love this type of work, and I would for sure get grime/dirt on the leather.
The recommended replacement interval is every 2 or 3 years? I’ll check was it was for my C63. Unfortunately, MB no longer publishes this info. They just want us to go in for the “A” or “B” service!
For me, I'd rather just do these myself than argue with a service writer. Today, these service departments are busier than ever. It took two weeks to get a service appointment for both the GT and the F-Pace. Both cars sat in the dealer's lot for a couple to 4 days before they could even get the cars in the bay.
Surge (05-05-2021)
I'm right with you on this one Katie! I either spent my time sitting on the sill or kneeling on the garage floor. At 6'5", I don't fold up all that well into small places like this one...hahaa..
Yes,
Surge (07-14-2022)
