Photo Request: Mounted OEM GT R Wheel, with Center Cap Removed
Old Jun 25, 2021 | 11:50 AM
MBNRG's Avatar
Unfortunately, GT R currently in shop in a different city for PPF which will take 2-3+ Weeks due to backlog
Would appreciate if anyone has, or can take, a photo of the GT R OEM Wheel mounted on car, with 3 Pointed Star Center Cap removed please.
I would like to check the clearance behind this center cap to see about potential fitment of the Rimgard wheel lock solution.
Thank you so much 🙏
Old Jun 25, 2021 | 03:33 PM
thecutter64's Avatar
2018 Solarbeam Yellow AMG GTS
I don’t have a photo but you can see it well in the following video:
Old Jun 25, 2021 | 03:58 PM
MBNRG's Avatar
Originally Posted by thecutter64
I don’t have a photo but you can see it well in the following video:https://youtu.be/XIGNTmIPTHA
Appreciate it, thank you. Unfortunately looking for a different wheel than the one depicted in Youtube video.
The GT R OEM wheel of interest (or the other 2 available GT R Wheels):
Old Jun 26, 2021 | 01:02 PM
user33's Avatar
Just completed a test fitting after installing TiKT brake-cooling ducts (and before putting in the single-use caliper/rotor bolts ... that's why there are only 3 wheel-bolts installed). Looks like 1 inch of usable clearance. Hope this helps and it'd be good to have a report on the results, if you do install the locks.
Old Jun 26, 2021 | 01:37 PM
MBNRG's Avatar
Wow, nice - THANK YOU 🙏
From the wheel and caliper finish - this is likely a GT R Pro, but hopefully we can assume same clearances as the GT R.
Will definitely report back with findings.
The Rimgard locks look to be such an elegant, effective solution if they fit!
The TiKT brake ducts - excellent; will be doing those soon as well 👍
Old Jun 27, 2021 | 12:59 PM
user33's Avatar
Sorry ... yes, it's a Pro but I'm pretty sure they're the same wheel. If you look at your build sheet and see an RXE wheel, then it's definitely the same.
The TiKT ducts are quite expensive, but I consider them to be an investment in that they should help the rotors (and pads) to last much longer (and the carbon-ceramic rotor cost is rather high).
Old Jul 26, 2021 | 10:20 PM
MBNRG's Avatar
I can confirm that the Rimgard wheel locks fit flawlessly on OEM GT R wheels and likely any other GT or MB OEM wheels (must be OEM) that have the sufficient clearance behind the center cap, as depicted in your photographs.
Rimgard locks appear the most effective and attractive solution for securing our OEM wheels that I've encountered in my research and experience, and are easily removable for access before a track day.
Alternatives that use variations of actual lug bolt, or lug nut (with stud conversion), etc are defeated with ease.
Old Jul 26, 2021 | 11:13 PM
mathechr's Avatar
2023 G550, 2020 AMG GTR, 2014 S550, 2024 Denali 3500, 2023 Porsche GT3
Sorry, I have never understood wheel locks. Maybe it's just a result of where I have lived over my adult life, but I can NEVER remember someone telling me that their wheels were stolen. This includes living in DC and Baltimore suburbs where the crime rates are not the best. Are wheel locks these days a solution looking for a problem? I'm certainly not taking my very expensive cars to someplace where I have to worry about theft or damage to begin with.
Old Jul 27, 2021 | 12:31 AM
MBNRG's Avatar
Then consider yourself lucky.
Other than perhaps your own locked garage on your private property, no "someplace" is safe, esp during this more acute desperation of Pandemic times.
If a knowledgeable theft team hits, wheels disappear in under 1-2 minutes, and you find your vehicle on cement blocks or worse.
OEM Wheels, especially MB OEM Wheels, are primary fodder for thieves.
Old Jul 27, 2021 | 04:57 AM
Stenzel-Germany's Avatar
AMG GTR
Hi,
This is my final solution: Minimally less weight (screws / sleeves are made of aluminum)
Quick and easy wheel change. Protection of the ceramic brake discs and, as an additional plus, increased theft protection.
Like the look.
Kind regards.
Stenzel
Old Jul 27, 2021 | 02:12 PM
user33's Avatar
Originally Posted by Stenzel-Germany
This is my final solution: ...
So are the black discs spacers and how/what is/does the "Protection of the ceramic brakes ..."?
Old Jul 28, 2021 | 04:38 AM
AMG GTR
Hi,
The protection of the carbon brake discs consists in the fact, when a wheel dismantled or reassembled, it is guided.
The rim can not hit the brake disc in an uncontrolled manner. (Murphys law)
Carbone discs are sensitive to lateral forces or impacts.
Wheel studs effectively prevent this.
Without fixed wheel studs, it is generally advisable to use a mounting stud.
One of the best tools.And so simple. A real recommendation for the tool kit.
There is a inexpensive (about 6.- USD) Mercedes-Benz aluminum mounting stud. (M14x 1.5)
Part number: A 204 581 00 74
Kind regards.
Stenzel
Old Jul 29, 2021 | 03:49 PM
user33's Avatar
... The protection of the carbon brake discs consists in the fact, when a wheel dismantled or reassembled, it is guided. ...
Thanks for the explanation ... and I agree WRT the CCB rotors. My approach is to screw in a pair of long "sissy bolts" when removing/installing a wheel/tire, along with a wheeled telescoping/pneumatic shop stool. I place the shop stool underneath the wheel then raise it enough to remove the bolt-riding friction then carefully pull the wheel/tire outwards on the wheeled/rolling support stool. The backs aren't too bad, but I think there's less than an inch clearance between the inside of the front rims and the CCB rotor edge so it'd be easy to chip them.
